#1
I was playing tutorial three and I had almost completed my pyramid when my laborers decided to ignore the fact that one more block of fine limestone needed to be placed. Instead, my laborers decided to haul out all of the blocks of limestone remaining in the quarry and to haul all of the imported blocks of fine limestone into the storage area. I tried setting both of my overseers to oversee construction, but that didn't help.
Anyone know why this happened? By the way, I didn't save the tutorial after I quite, but I could probably conjure up the auto save if it's necessary. |
#2
Just keep the overseer's at "oversee constuction" and keep an eye on them when they finish fluffing around they will finish the pyramid.
#3
I don't set them to quarry duties for very long, and keep everything cleaned up. Most of my overseers are set on overseeing construction for most of the time. When all the stones are pulled out.. set an overseer for a short time to quarry. That should give you enough stones for building quite a long time.
It seems the labour remembers the orders for a while. |
#4
I let one overseer do nothing, and one was overseeing construction, but the laboreres still just kept hauling the blocks of limeston out of the quarry even though there were at least 30 already stockpiled.
#5
Quote:
Move the CDA away from the ramp further up by the corner of the pyramid and a few tiles further out than it's present location. OR If you see villager huts or vagrant mats appearing in the area near the ramp, carefully delete these. They may want to rebuild in the same area, but just keep "popping" the huts and mats as they appear until they all move out of that area. Before you do this, make a manual save of your game so you can go back if you find it doesn't help. ![]() Keith Heitmann a.k.a Nuthin-in-khamun Listen to the music of the CityBuilders while online: Caesar III Music Player•Pharaoh Music Jukebox•Zeus Music Jukebox•Emperor's Music Box•Children of the Nile Musicbox• Children of the Nile & Quiz•Visit PlanetNile |
#6
Quote:
EDIT: I checked for vagrant mats and villager huts, there were none. Then I proceeded to delete the drop-off point and put it a little farther away and waited. Same thing as before happened. I'm thinking that hauling stuff out of the quarry must have had a higher priority. Last edited by Ghostmonkey; 11-08-2004 at 04:31 PM. |
| Thread Tools | |
| Display Modes | |
