New System - Need Help
MAX-1
Postby MAX-1 » Sat Nov 10, 2007 10:50 am
Well,
I finally bit the bullet and bought a new system.
Installed COTN right away with patch. Game launched very well and extremely fast. WOW :eek:
I went to play a scenario and it crashed to desktop.
I can play the tutorial, but there is a slight flicker.
Here's DIX file. :D
wgengland
Postby wgengland » Sat Nov 10, 2007 12:08 pm
I see you are running Vista. killor06 had a similar problem until he setup the game to run as "administrator". If he got the game to work under Vista, then perhaps he knows the correct incantation. :D
killor06
Postby killor06 » Tue Nov 13, 2007 9:22 pm
wgengland wrote:I see you are running Vista. killor06 had a similar problem until he setup the game to run as "administrator". If he got the game to work under Vista, then perhaps he knows the correct incantation. :D
yes but thus leads to no custom files
