Game Crashes - Please help
kitytje
Postby kitytje » Mon Dec 28, 2009 10:44 pm
Every time I try to play a campaign, the game crashes. The tutorials work fine. I have read the forum and tried installing new video drivers, reducing the number of background programs running and installed directx 9. It still doesn't work. Do I need a better video card? I tried to check the list of appropriate cards but it does not show up. Please help.
Postby mouse » Tue Dec 29, 2009 4:45 am
Your video card is fine and your system looks good. The problem is with Vista not playing nice with the game. Have you tried to either play the game in XP mode or as admin. Another thing that could be a problem is your virus scanner might be a problem you can try turning off your virus scanner before you play. The reason the campaigns cause a crash is that they demand more of your system than the tutorials do. Have you installed the patches to the game if you are playing from the cd. Try the things I've suggested then post back to let us know of any of them help.
kitytje
Postby kitytje » Thu Dec 31, 2009 2:32 pm
Hi mouse,
Thanks so much for your response. I am unsure how to play the game in XP mode or as admin (I don't really know what this is!) I will try if you could explain. My virus scanner (I think) is Forefront, which I am not sure actually works but I don't think it is a separate program the way McAfee is, so I really have no idea if it is on and how to turn it off (my windows says I have no virus scanner). I have also tried to download the 1.3.0.1 patch from the immortal cities website, but whenever I try it it tells me that my version of the executable is unknown and aborts. Are there other patches I should be trying?
Thanks!
Postby Keith » Thu Dec 31, 2009 3:23 pm
Right click on your cotn.exe file located in the folder where the game was installed. Select "run as" from the menu and set the option for "administrator."
From the same right click menu, click on properties, then the compatability tab. Set the mode to XP. Click APPLY and OK.
