Shortcut Keys
lockdown643
Shortcut Keys
Postby lockdown643 » Tue Apr 20, 2010 4:41 am
I am having problems with adjusting my game speed settings. When I push "minus" on my keyboard, the box pops up to show the game speed is 0.5. But I cannot increase that game speed. I have a laptop that doesnt have a Num pad and I think thats part of the problem because I have to hit "Shift" and "Equal/Plus" button to give it the command of the plus sign, but it does not increase the game speed. How can I increase my game speed or change the keyboard shortcut. I have the Enhanced Edition also if that makes a difference.
Postby Keith » Tue Apr 20, 2010 5:08 am
[FONT=Verdana][SIZE=2]+ and -, or = and - Increase or decrease game speed
[/SIZE]Page 46 of the manual.pdf file has all the game's hotkeys.[/FONT]
lockdown643
+ or -, = or -
Postby lockdown643 » Tue Apr 20, 2010 5:22 am
After continuing to do some research, that's what I discovered but it still does not increase the game speed. Is it some how capped at 0.5? Can I change the hot key to test it or something?
Postby Yahya » Tue Apr 20, 2010 12:13 pm
By default, the game speed can be set anywhere from 0.5 to 2.5 in increments of 0.5.
I'm not sure why you can't increase above 0.5. That's very unusual. Are you using a non-US keyboard or a computer that thinks you're using one? That could cause a keystroke problem, I suppose.
Postby Keith » Tue Apr 20, 2010 1:41 pm
It is also possible that you may have a bad install. You can try uninstalling and reinstalling the game, if everything else fails.
Postby sakasiru » Tue Apr 20, 2010 3:26 pm
I think I read about the problem before, that the + doesn't work on laptops...
Found this thread here:
http://www.tiltedmill.com/forums/showthread.php?t=25183&highlight=increase+speed
maybe this helps?
callysto
Postby callysto » Wed Apr 21, 2010 2:52 pm
i have the same problem, i cant indrease the game speed, on-screen keyboard does not seem to work. i am using a laptop with an american keyboard with no numpad. any further ideas?
lockdown643
Old Forum Thread
Postby lockdown643 » Thu Apr 22, 2010 12:24 am
Thank you for telling me about the old forum thread! That is a good temporary solution to the problem. In the Cotn.ini file changing "Fullscreen 1" to be "Fullscreen 0" put the game in windowed mode and allows me to use the onscreen keyboard and it allows me to speed it up now! :D If anyone else can find out a permanent fix that would be great. Otherwise this temporary fix works pretty well for me. Thanks!
