Lag even on blank map
molotof
Postby molotof » Tue Oct 06, 2015 10:36 am
Hi
I've got a lag issue on the game all the time, even on a new map. The framerate seems clunky but i managed to monitor it with fraps : 60 fps.
All other game run just fine.
Some detail : when paused i can scroll without having lag but if i rotate the camera , lag.
I digged the forum in hope to find a solution, here is what i tried :
Updating Driver, reinstalling, turning all graphic option to the lower, changing resolution, checking refresh rate, windows compatibilty mode, nvidia scaling options, unistalling logitech mouse driver, killing all unnecessary process and service.
Love the game but it's not really enjoyable like this. Hope somebody can help me
Here is my dxdiag :
Code: Select all
System Information
Time of this report: 10/6/2015, 11:49:02
       Machine name: MOLOTOF-PC
   Operating System: Windows 7 Édition Intégrale 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150316-1654)
           Language: French (Regional Setting: French)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: BIOS Date: 12/15/10 19:35:35 Ver: 08.00.15
          Processor: Intel(R) Core(TM) i7 CPU         860  @ 2.80GHz (8 CPUs), ~2.8GHz
             Memory: 8192MB RAM
Available OS Memory: 8190MB RAM
          Page File: 3490MB used, 12886MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 760
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 760
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1187&SUBSYS_847A1043&REV_A1
     Display Memory: 4038 MB
   Dedicated Memory: 1990 MB
      Shared Memory: 2048 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Moniteur Plug-and-Play générique
      Monitor Model: PL2409HD
         Monitor Id: IVM560C
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: DVI
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 10.18.0013.5598 (English)
     Driver Version: 10.18.13.5598
        DDI Version: 11
       Driver Model: WDDM 1.1
   Driver Date/Size: 9/14/2015 02:29:48, 15513208 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B71E3E-52C7-11CF-2D66-77A41CC2C735}
          Vendor ID: 0x10DE
          Device ID: 0x1187
          SubSys ID: 0x847A1043
        Revision ID: 0x00A1
 Driver Strong Name: oem22.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section032:10.18.13.5598:pci\ven_10de&dev_1187
     Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: SPDIF Interface (TX1) (VIA High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_0441&SUBSYS_104383E4&REV_1001
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: viahduaa.sys
         Driver Version: 6.00.0001.7430 (English)
            WHQL Logo'd: n/a
          Date and Size: 7/28/2009 14:07:58, 1225216 bytes
            Other Files:
        Driver Provider: VIA Technologies, Inc.
         HW Accel Level: Basic
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: SPDIF Interface (TX0) (VIA High Definition Audio)
 Default Sound Playback: No
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: Haut-parleurs (VIA High Definition Audio)
 Default Voice Playback: Yes
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
Sound Capture Devices
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: G700 Laser Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC06B
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: USB Receiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52B
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC531
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x8086, 0x3B34
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 11/27/2013 03:41:37, 343040 bytes
| Driver: usbd.sys, 11/27/2013 03:41:03, 7808 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Périphérique clavier PIH
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/20/2010 12:33:25, 33280 bytes
| Driver: kbdclass.sys, 7/14/2009 03:48:04, 50768 bytes
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 01:19:57, 105472 bytes
+ Souris HID
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 02:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 03:48:27, 49216 bytes
+ Souris HID
| Service: mouhid
+ Souris HID
| Service: mouhid
+ Souris HID
| Service: mouhid
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 15:33:57, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 02:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 22.2 GB
Total Space: 143.1 GB
File System: NTFS
      Model: WDC WD1500HLFS-01G6U0 ATA Device
      Drive: D:
 Free Space: 9.7 GB
Total Space: 476.9 GB
File System: NTFS
      Model: Hitachi HDP725050GLA360 ATA Device
      Drive: E:
 Free Space: 24.0 GB
Total Space: 305.2 GB
File System: NTFS
      Model: SAMSUNG HD321KJ ATA Device
      Drive: F:
 Free Space: 25.2 GB
File System: NTFS
      Model: WDC WD1001FALS-00J7B0 ATA Device
      Drive: G:
 Free Space: 58.8 GB
File System: NTFS
      Drive: H:
 Free Space: 326.6 GB
Total Space: 1907.7 GB
File System: NTFS
      Model: WDC WD2002FAEX-007BA0 ATA Device
      Drive: I:
 Free Space: 271.1 GB
File System: NTFS
      Model: WDC WD20EZRX-00D8PB0 ATA Device
      Drive: L:
      Model: PLEXTOR DVDR   PX-L890SA ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (French), 11/20/2010 11:19:21, 147456 bytes
      Drive: J:
      Model: DTSOFT Virtual CdRom Device
      Drive: K:
System Devices
     Name: Intel(R) processor DMI - D131
Device ID: PCI\VEN_8086&DEV_D131&SUBSYS_83831043&REV_11\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_83831043&REV_05\3&11583659&0&E8
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.18328 (English), 11/27/2013 03:41:11, 53248 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.18328 (French), 11/27/2013 03:41:11, 325120 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.18328 (French), 11/27/2013 03:41:37, 343040 bytes
     Name: TP-LINK Wireless N Adapter
Device ID: PCI\VEN_168C&DEV_0023&SUBSYS_3071168C&REV_01\4&2D87D632&0&10F0
   Driver: C:\Windows\system32\DRIVERS\athrx.sys, 8.00.0000.0297 (English), 1/27/2010 17:25:42, 1584640 bytes
   Driver: C:\Windows\system32\drivers\vwifibus.sys, 6.01.7600.16385 (French), 7/14/2009 02:07:21, 24576 bytes
     Name: Intel(R) processor Miscellaneous Registers - D158
Device ID: PCI\VEN_8086&DEV_D158&SUBSYS_00000000&REV_11\3&11583659&0&43
   Driver: n/a
     Name: Contrôleur audio haute définition
Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_83E41043&REV_05\3&11583659&0&D8
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (French), 11/20/2010 12:43:43, 122368 bytes
     Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_83831043&REV_05\3&11583659&0&FB
   Driver: n/a
     Name: Contrôleur d’hôte compatible OHCI 1394 VIA
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&2D87D632&0&18F0
   Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (French), 11/20/2010 12:44:56, 229888 bytes
     Name: Intel(R) processor System Control and Status Registers - D157
Device ID: PCI\VEN_8086&DEV_D157&SUBSYS_00830043&REV_11\3&11583659&0&42
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 8 - 3B50
Device ID: PCI\VEN_8086&DEV_3B50&SUBSYS_83831043&REV_05\3&11583659&0&E7
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (French), 11/20/2010 15:33:48, 184704 bytes
     Name: Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller - 3B26
Device ID: PCI\VEN_8086&DEV_3B26&SUBSYS_83831043&REV_05\3&11583659&0&FD
   Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 03:45:45, 12352 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (French), 7/14/2009 03:45:46, 48720 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 03:52:21, 24128 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.18231 (French), 8/5/2013 04:25:45, 155584 bytes
     Name: Realtek PCI GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8167&SUBSYS_820D1043&REV_10\4&2D87D632&0&20F0
   Driver: n/a
     Name: Intel(R) processor Semaphore and Scratchpad Registers - D156
Device ID: PCI\VEN_8086&DEV_D156&SUBSYS_00830043&REV_11\3&11583659&0&41
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 7 - 3B4E
Device ID: PCI\VEN_8086&DEV_3B4E&SUBSYS_83831043&REV_05\3&11583659&0&E6
     Name: Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller - 3B20
Device ID: PCI\VEN_8086&DEV_3B20&SUBSYS_83831043&REV_05\3&11583659&0&FA
     Name: NVIDIA GeForce GTX 760
Device ID: PCI\VEN_10DE&DEV_1187&SUBSYS_847A1043&REV_A1\4&113C73B2&0&0018
   Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 448120 bytes
   Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 9/14/2015 02:29:48, 1304764 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_neutral_165d36a99c4de2fd\NvCplSetupInt.exe, 1.00.0005.0000 (French), 9/14/2015 02:29:48, 95421520 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 9/14/2015 02:29:48, 12080 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 154256 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 105328 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 9/14/2015 02:29:48, 11896 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 184304 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 125904 bytes
   Driver: C:\Program Files\NVIDIA Corporation\license.txt, 4/9/2015 02:58:18, 21910 bytes
   Driver: C:\Program Files\NVIDIA Corporation\nvgsync\detoured.dll, 9/14/2015 02:29:48, 11896 bytes
   Driver: C:\Program Files\NVIDIA Corporation\nvgsync\nvgsyncdetours.dll, 9/14/2015 02:29:48, 154232 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (French), 9/14/2015 02:29:48, 841336 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 227960 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 9/14/2015 02:29:48, 72643 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 415536 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 1196336 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.02.0011.0000 (English), 9/14/2015 02:29:48, 105080 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.02.0011.0000 (English), 9/14/2015 02:29:48, 112760 bytes
   Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 11096696 bytes
   Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 1074808 bytes
   Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 1064056 bytes
   Driver: C:\Windows\system32\NvIFROpenGL.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 408184 bytes
   Driver: C:\Windows\system32\nvEncodeAPI64.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 512904 bytes
   Driver: C:\Windows\system32\nvapi64.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 3530608 bytes
   Driver: C:\Windows\system32\nvcompiler.dll, 9/14/2015 02:29:48, 42840368 bytes
   Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 14936264 bytes
   Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.5598 (English), 9/14/2015 02:29:48, 2940024 bytes
   Driver: C:\Windows\system32\nvd3dumx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 15513208 bytes
   Driver: C:\Windows\system32\nvinfo.pb, 9/14/2015 02:29:48, 33079 bytes
   Driver: C:\Windows\system32\nvinitx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 176904 bytes
   Driver: C:\Windows\system32\nvoglshim64.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 150832 bytes
   Driver: C:\Windows\system32\nvoglv64.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 22525560 bytes
   Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 16637528 bytes
   Driver: C:\Windows\system32\nvumdshimx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 1105976 bytes
   Driver: C:\Windows\system32\nvwgf2umx.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 17082928 bytes
   Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 944760 bytes
   Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 986232 bytes
   Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 364152 bytes
   Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.5598 (English), 9/14/2015 02:29:48, 421544 bytes
   Driver: C:\Windows\SysWow64\nvapi.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 3116160 bytes
   Driver: C:\Windows\SysWow64\nvcompiler.dll, 9/14/2015 02:29:48, 37819000 bytes
   Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 12185344 bytes
   Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.5598 (English), 9/14/2015 02:29:48, 2627192 bytes
   Driver: C:\Windows\SysWow64\nvd3dum.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 12514824 bytes
   Driver: C:\Windows\SysWow64\nvinit.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 155792 bytes
   Driver: C:\Windows\SysWow64\nvoglshim32.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 128512 bytes
   Driver: C:\Windows\SysWow64\nvoglv32.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 18543736 bytes
   Driver: C:\Windows\SysWow64\nvopencl.dll, 8.17.0013.5598 (English), 9/14/2015 02:29:48, 13660648 bytes
   Driver: C:\Windows\SysWow64\nvumdshim.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 943712 bytes
   Driver: C:\Windows\SysWow64\nvwgf2um.dll, 10.18.0013.5598 (English), 9/14/2015 02:29:48, 14635600 bytes
   Driver: C:\Windows\system32\nvdispco6435598.dll, 2.00.0043.0004 (English), 9/14/2015 02:29:48, 1898288 bytes
   Driver: C:\Windows\system32\nvdispgenco6435598.dll, 2.00.0021.0002 (English), 9/14/2015 02:29:48, 1558832 bytes
     Name: Intel(R) processor System Management Registers - D155
Device ID: PCI\VEN_8086&DEV_D155&SUBSYS_00830043&REV_11\3&11583659&0&40
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
Device ID: PCI\VEN_8086&DEV_3B4C&SUBSYS_83831043&REV_05\3&11583659&0&E5
     Name: Intel(R) P55 Express Chipset LPC Interface Controller - 3B02
Device ID: PCI\VEN_8086&DEV_3B02&SUBSYS_83831043&REV_05\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 03:48:27, 15424 bytes
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_847A1043&REV_A1\4&113C73B2&0&0118
     Name: Intel(R) QuickPath Interconnect - D151
Device ID: PCI\VEN_8086&DEV_D151&SUBSYS_00000000&REV_11\3&11583659&0&81
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 5 - 3B4A
Device ID: PCI\VEN_8086&DEV_3B4A&SUBSYS_83831043&REV_05\3&11583659&0&E4
     Name: Pont Intel(R) 82801 PCI - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_83831043&REV_A5\3&11583659&0&F0
     Name: Intel(R) QuickPath Interconnect - D150
Device ID: PCI\VEN_8086&DEV_D150&SUBSYS_00000000&REV_11\3&11583659&0&80
   Driver: n/a
     Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_83831043&REV_05\3&11583659&0&E0
     Name: Contrôleur IDE standard double canal PCI
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_824F1043&REV_03\4&61613AC&0&00E7
     Name: Intel(R) processor PCI Express Root Port 1 - D138
Device ID: PCI\VEN_8086&DEV_D138&SUBSYS_83831043&REV_11\3&11583659&0&18
     Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_83831043&REV_05\3&11583659&0&D0
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_824F1043&REV_03\4&1D970CF4&0&00E6
Re: Lag even on blank map
Postby Yahya » Wed Oct 07, 2015 8:14 am
Hi molotof,
That's odd. With your machine specifications there should be no trouble at all. The only thing that I thought when reading your post was that the fog distance could be turned down. That causes a lot of lag if turned up too high.
However, you said you turned all graphics options to minimum and still had the problem, and your machine should easily be able to run an 11 year-old game like CotN.
By any chance are you running a custom-built scenario? Lag is caused by the number of sprites in the game, and if there are a lot of reeds, for example, lag can really go up.
molotof
Postby molotof » Wed Oct 07, 2015 12:16 pm
Hi, thank for the reply, i figured out last night, after lots of trying, i found it, that was directx that was messing with me, installed DX 9c, done some registry cleanig, rebooted and now the game is smooth like butter.
Postby Yahya » Wed Oct 07, 2015 5:58 pm
Excellent. Enjoy!
