Set Next Flood
Set Next Flood
Postby Yahya » Wed Oct 13, 2010 12:04 pm
I seem to remember a discussion here about next flood some time back, but I can't find it.
Specifically, I'm looking for the timing necessary, i.e., when you use Set Next Flood, how long before Achet must it be set?
Anyone have an idea?
Postby sakasiru » Thu Oct 14, 2010 8:06 am
Since there is a forecast how good the next flood will be, you should set the flood before this appears.
I have done this before, but I didn't experiment much how long before I should set it. I think I just fired the trigger the moment the previous flood came.
Postby Yahya » Thu Oct 14, 2010 9:19 am
That's a good point. I suppose you could set a trigger that meets condition one and then waits for the flood to occur. Once both are true, it triggers the next flood condition and fires.
Then once the flood starts, you could have another trigger turn that one on if you wanted it to fire again.
Postby Tinkerbell » Thu Oct 14, 2010 4:02 pm
Check out Jimaaten's Seven Fat Seven Lean UCS, Yahya. It has 7 failed floods in a row.
Postby Yahya » Thu Oct 14, 2010 7:31 pm
Thank you. I knew there was one like that, but couldn't remember which one.
