The Keep
Karter
The Keep
Postby Karter » Thu Mar 01, 2007 4:54 pm
I HAVE NOT TESTED THIS IN VISTA
OMG well after 2 months plus+
I believe I have actually finished this scenario
For those who have been so patient and those who's input has been so helpful.. I thank you and hope it is worthy
For I now offer you the:
The Keep ...and The Valley of The Ancients
I have tried to create an entirely magical land,
which you will have to journey to, too rebuild a forgotten city know as The Keep.
Your father has recently passed away and you vow to build his great tomb
and perform Ancient rituals of the "Old Ones", whose chants were transcribed
onto, the now lost, scrolls of knowlege.
You start off with a scripted Movie
Pharaoh and his Adivors
played at opening speed .5
In this, you will be dealing with
  • Mythical beast
  • Ancient cities
  • Mystical artifacts
  • Orbs of Power
  • 5 granite monoliths
  • Scrolls of knowlege
  • The Book of Wonder
  • sfx special effects
  • character sound files
battling
  • The Gods
  • Mother Nature herself
  • the plague
  • and the half-man half-beast creatures of Seth's evil forces
This is an
Inter-Active scenario
You must interact with objects to perform necessary actions
Messages and clues are given, objects response will change as the storyline progresses
pausing the game stops interaction with objects...simply unpause to resume
map size : 150 x 150
difficulty : umm hard to say, cheats, hints and walk-through are provided just in case
playtime : should be 25-32 years depending on how things go
Since this is storyline driven,
the goals at first may seem a little vague, but should unfold as you journey on
HINTS
I strongly suggest the following
Limestone Quarry, wait until you have the Eye of Ra placed
build your city as the CoTN guide suggests
read the tips section for special settings
DO NOT leave unattend for long
either pause the game or save and reload when you want to begin again
you could come back to a not so pretty situation, depending on where you
are at in the game.. :)
SPECIAL NOTES
see tips section for resolution settings...I recommend 1024 x 768 for best displaying options
Game play, because of the limitations built into the editor,
trying to time responses for different speed settings and different computer types is very difficult.
Hopefully, I have struck a good balance.
Those with minimum requirement machines (such as myself)
close to the end of the scenario, response may begin to lag...LOL correction WILL begin to lag
Just allow a little time for them to show
I had highest settings up until about the last 20%-25% of the scenario...and run 1.6Ghz with only 512ram
but have a decent graphics card
INSTALLING
Regrettably due to sound files, this is a 13MByte file size
For Auto-Installer
click the following link
www.ItsMyLyfe.com/COTN/TheKeep_install.exe
and just click RUN or you can save it to disk and run later
For Our Dial-up freinds
if you have difficulty downloading large files
I have split up the sound files into smaller .zip files allowing you to
download a part at a time, this hopefully, may help in an easier retrieval.
these are located at the bottom of this post
put the
TheKeep.scn goes into your C:\Program Files\Tilted Mill\Children of the Nile\data\Scenarios folder
unzip your other files into a dummy directory
the theme
TheKeep.mp3 goes into your C:\Program Files\Tilted Mill\Children of the Nile\data\Audio\Sounds folder
you must create a folder called TheKeep in your sound directory as such
C:\Program Files\Tilted Mill\Children of the Nile\data\Audio\Sounds\TheKeep
and copy the rest of the .mp3 files into it
If you extract sound_part1.zip and sound_part2.zip with the use folder name option checked you can extract them directly to the
For Our Hearing-Impaired Friends
You should easily be able to follow the story-line, as pop-up messages and the Book of Wonder tracks items of interest for you
Sound files are not needed...they are simply for me...since my attention span is next to "0"
just download the
TheKeep.scn file directly into your
C:\Program Files\Tilted Mill\Children of the Nile\data\Audio\Scenarios folder
IMPORTANT ALL MANUAL INSTALLS
you will need this additional file
it can be downloaded here
http://www.ItsMyLyfe.com/COTN/wl_map_TheKeep_1_1.dds
it must go into your
C:\Program Files\Tilted Mill\Children of the Nile\data\Graphics\world level\map folder
Playing the Scenario
Once installed
Start your CoTN game as normal
click on play scenario
and select The Keep
Last Thoughts
Please let me know if you have difficulties
and other than taking stone carvers a little bit of extra time at cutting up a pyramid
the scenario should move along at a reasonable pace.
Customize your end scenario
If you saved off your end game,
you can look at the end of the cheat file to see how to cusomize your scenario
to your own liking
I offer a small peek at what it has to offer, you can watch the movie Trailer (if you can view .wmv files-windows format)
The links are here
TheKeep_dialup.wmv (dial-up version 3.0MB size)
TheKeep_small.wmv (small version 23.0MB size)
TheKeep_Theatre.wmv (theatre version 49.0MB size)
Last correction:
March 02, 2007
included world map
March 07, 2007
typo corrections
Kiya
Postby Kiya » Thu Mar 01, 2007 5:57 pm
OOOH, this scenario sounds so exciting, can't wait to play it next week end. Azeem's pretty contest was so much fun and now this! Thank you Karter :)
*Kiya tanssahtelee ja pompahtelee tuolillaan* :)
existenz
Postby existenz » Thu Mar 01, 2007 8:59 pm
Thanks Karter, have been waiting for this one. Have downloaded it and will play today.... :)
Ok tried to play this, can watch the movie, play on the city level, no lag but whenever I try to open the world level I get a CTD no matter what I try. Have a save if you want to look at it - can pm you with it so I don't give anyone any spoilers or just post it. It is in the 2nd year of the game.
Edit2: By the way I first downloaded the complete zip sounds file but there were no sound files in the Keep folder - had to download the seperate sound files 1 and 2 to get those. Don't know if that made a difference - perhaps I should delete and re download the scenario and soundfiles again in case it was corrupted somehow?
JRGJD
Tooyyss!!
Postby JRGJD » Fri Mar 02, 2007 12:58 am
EXCELLENT!!
Thank you so much, Karter!
The timing is great, as well.
This has been a particularly intense week, and I am SO ready for a break! :D (bows to the north)
So, I'm off to explore the Valley of Ancients. I'll let you know what I find!!
JR :cool:
EDIT: OK. Good news, bad news. First, the map is sweet! Volcano?!!? Hippo World?!!? Excellent resource placement, very pretty arrangement. Sweet touch with the moonset in the opening movie, BTW.
Bad news: There is definitely a CTD problem when you go to the WL map. Also, the installer installs to the wrong folder. It creates a new folder named "Scenarios" in the main CotN directory. It should go to the pre-existing Scenarios folder in the data folder. Otherwise the game can't find the file (wrong path). The mis-filing is easy to fix on the user end. CTD, not so much (but I suspect it is a minor bug--not a coder, though) :D
The city looks great though, and I'll probably play just because it's cool; until you fix the bug that is....
JR
Karter
Postby Karter » Fri Mar 02, 2007 9:08 am
ooopsssssss
thank you, I thought I had everything included
this scenario uses a special world map....
I have never used one before, so when I was uploadiing everything forgot to add it
I have made the appropriate corrections
You can either just re-install using the auto-installing
OR
you can directly download the map here
folder
Thank you for the feedback
sorry about that :(
existenz
Postby existenz » Fri Mar 02, 2007 10:11 am
Thanks for the quick response. I downloaded the auto installer file earlier but now have the world map installed.... Unfortunately its after 9 pm here and have an early start for work tomorrow but will definately try again tomorrow afternoon and get back to you. I hate work getting in the way of play!!! :D
Karter
Postby Karter » Fri Mar 02, 2007 10:18 am
existenz wrote:Thanks for the quick response. I downloaded the auto installer file earlier but now have the world map installed.... Unfortunately its after 9 pm here and have an early start for work tomorrow but will definately try again tomorrow afternoon and get back to you. I hate work getting in the way of play!!! :D
I did have a bad version...so not sure exactly when you made your update
but....everything is correct now...you may want to update just in case
files all go to their proper spots
and everything is included
if you just needed the map and just installed that then you should be good to go
sorry for the problem
I was so tired when I was uploading everything and creating the installer
guess that will teach me
existenz
Postby existenz » Fri Mar 02, 2007 10:21 am
No I had no problem getting the installer to work - having an International version I had to change the install directory anyway i.e. C:\ Sega\ImmortalCities\. But did try the world level with the new world map installed and it works perfectly now. Thanks! :D Can't wait!
texasmine
Postby texasmine » Fri Mar 02, 2007 1:33 pm
Do the zipped sound files go into the ....sounds\thekeep folder also?
JRGJD
Postby JRGJD » Fri Mar 02, 2007 4:27 pm
sorry about that :(
Downloaded it! Thanks!
I played Men-Nefer last night instead of poking around in the Keep. That's for tonight.
I'll report back....
JR ;)
Kiya
Postby Kiya » Fri Mar 02, 2007 7:31 pm
I downloaded the 'auto-installer' and all went fine. Didn't play actually but had a look around the map and WM too. The scenario looks very intriguing, its sounds are awesome. Thanks Karter. :)
Karter
Postby Karter » Fri Mar 02, 2007 7:58 pm
texasmine wrote:Do the zipped sound files go into the ....sounds\thekeep folder also?
if not using the auto-installer then yes
of course you need to use WinZip or PkZip something like that to extract them
you need to make a folder in the sounds directory
and move the .mp3 and .wav files into it from
sound_part1.zip
sound_part2.zip
if you check mark the use folder names option in winzip
you can extract them directly into your sounds directory and the folder will automatically be created
the sound_theme.zip goes directly in the
C:\Program Files\Tilted Mill\Children of the Nile\data\Audio\Sounds directory
hope that makes sense
If done correctly the opening scene has Mount Katrina erupting with lava and smoke
and you should hear the eruption sound <explosion><rumbling> at the same time
please note if you are manually installing
you will also need to download the world map directly into your
Tilted Mill doesnt allow .dds uploads thats why i didnt upload it here
sorry it's so complicated :(
but I hope it is worth it
thnkx
Karter
Postby Karter » Fri Mar 02, 2007 7:59 pm
Kiya wrote:I downloaded the 'auto-installer' and all went fine. Didn't play actually but had a look around the map and WM too. The scenario looks very intriguing, its sounds are awesome. Thanks Karter. :)
You are more than welcome
I hope people find it enjoyable, it is a bit different than most scenarios
Kiya
Postby Kiya » Fri Mar 02, 2007 8:26 pm
Yes, even the very start looks stunning compared to most scenarios, and if the rest is like the beginning then I must say it's more than *a bit* different. ;) :D
existenz
Postby existenz » Sun Mar 04, 2007 5:34 am
Well just finished and I have to say this is the best scenario of any game I have ever played. Everything flowed perfectly and kept my interest throughout. Stunning visuals, great storyline and comments throughout, I especially liked the comment on the success screen. not posting any screenshots as that would spoil it for those yet to play. Maybe later! Great work Karter, can't wait for your next. You should be working for TM!! :)
Karter
Postby Karter » Sun Mar 04, 2007 4:09 pm
existenz wrote:Well just finished and I have to say this is the best scenario of any game I have ever played. Everything flowed perfectly and kept my interest throughout. Stunning visuals, great storyline and comments throughout, I especially liked the comment on the success screen. not posting any screenshots as that would spoil it for those yet to play. Maybe later! Great work Karter, can't wait for your next. You should be working for TM!! :)
Your words are very kind, thank you....
I greatly worry about people being able to follow the storyline, it is a little difficult to follow
and I am never certain how people will respond to this type of scenario
its not the typical CoTN city building type
and trying to make it challenging enough, but keeping it easy enough for first-timers, is within itself a challenge, I hope it is balanced enough to keep all interested
Again, I am glad you enjoyed it
guns&gardens
Postby guns&gardens » Mon Mar 05, 2007 10:04 pm
karter that was the best scenario i've ever played. had me so mad i wanted to throw the computer out the front door, especially when the you know what's disappeared :eek:
Karter
Postby Karter » Tue Mar 06, 2007 11:59 am
guns&gardens wrote:karter that was the best scenario i've ever played. had me so mad i wanted to throw the computer out the front door, especially when the you know what's disappeared :eek:
YIKES
<karter bites his nails frantically>
Now...now...in all fairness I did leave a fairly complete cheat & hints walk-through guide...
" I'ss-sss, hope-ss-ss you-ss-ss play-ss-ed it
all-ss-sss the ways-ss-sss throughs-sss-sss...
The secret-ss-ssss to-ss-sss eternals-s-ss-ss life-ss-sss
iss-ss very-ss-ss importants-sss-sssss "
MarkDuffy
Postby MarkDuffy » Fri Mar 09, 2007 6:26 pm
HeeeEEEy, some of them thar World Map towns sound kinda familiar...
LisaMockingbird
Postby LisaMockingbird » Sat Mar 10, 2007 4:05 pm
Can't wait to give this a try. I re-played your last 4 old ones a few months ago. Each one has gotten better and better - so this one should be spiffy! I like the extras you add in voice, movies, and different/map usages. :D
Users browsing this forum: No registered users and 9 guests
