Quiz: Roman History and Culture
moodringer10
Postby moodringer10 » Mon Mar 19, 2007 8:09 pm
two...
sniff sniff....
*single tear*
Postby Keith » Mon Mar 19, 2007 11:42 pm
Keep trying...it could have been worse! You could have gotten a minus score! ;) :D
Actually the more you play it the better you should eventually do. The gameset of questions changes each time you play so you may get some of the same one's again right away or eventually. Right now there are some 160 questions total that the game can draw from (until I add more...muhaha (best evil laugh.))
MarkDuffy
Postby MarkDuffy » Mon Mar 19, 2007 11:48 pm
Keith wrote:Keep trying...it could have been worse! You could have gotten a minus score! ;) :D
:eek:
EDIT:
:p
Postby Keith » Tue Apr 16, 2013 9:19 pm
I've corrected the link to the quiz at the top of this thread. So it should work again.
Use your keyboard to answer the questions by typing in the letter next to the correct answer during the quiz.
Some questions are easy and some are very hard. There are True/False, multiple choice, and questions that require more than one correct answer.
You won't have a lot of time to read the question and type in the letters of your answer of choice.
The quiz is a set of 25 drawn randomly from a pool of 160 questions in the database. If you take the quiz more than once you might see the same question again and you might not.
You will need JAVA installed to run this quiz.
Give it a try. You might learn something.
