Resulution problem vista 32-bit
ThunfischXX
Postby ThunfischXX » Wed Apr 22, 2009 2:21 pm
Hi i am new here and i have the german version of caeser IV.
Now here is my problem: When i go in the game i can't get my mouse pointer in the right and under few centimetres at the sites.
i already tried all but it always doesnt't work. :( :(
i have: vista 32-bit,directx9/10 and a nvidea graphic chip
Hope for a answer ThunfischXX
Postby Keith » Wed Apr 22, 2009 5:29 pm
You didn't attach your dxdiag.txt file to your post.
Is it a nVidia "chip" or do you have a nVidia video card? (The dxdiag.txt file will answer this and a number of other questions.)
ThunfischXX
Postby ThunfischXX » Wed Apr 22, 2009 8:01 pm
where i can find it?
i found an systeminformation but i can't copy it here :(
sorry for my spamming but i just can work a little bit with sniffing and c++ :\
Postby mouse » Wed Apr 22, 2009 8:41 pm
Go to run type in DX diag then save the text file and upload the text for DX diag. Continuing to ask questions for more information is not spamming we welcome your questions.
Postby Keith » Thu Apr 23, 2009 1:10 am
I don't know what the labels for these are if you have a german version of Windows installed.
As Mouse said, click START then in the RUN.
Then type "dxdiag" in the box without the quotation marks.
Click OK.
Let the program finish, then click the SAVE ALL INFORMATION button and save the resulting dxdiag.txt file to some place easy to find it like My Documents.
Then come back to this thread and start a new reply. Below the typing area there is a Manage Attachments button. Click on it. Browse the folder where you saved the dxdiag.txt file and select it. Then click on the UPLOAD button. Once the file has been uploaded you can close the file manager window. Then type a message in the reply you opened and then click on SUBMIT REPLY.
Phil Walker
To Add
Postby Phil Walker » Thu Apr 23, 2009 4:39 am
Adding to what Keith and Mouse have said. Do not be concerned with your language either. We have other Germans on this site as well who can translate if you wish to use your native language. One of our techs (Manni) is also German and can assist.
If you mean a C++ Runtime Library error, this indicates you usually have too much running in the background which the DxDiag will also reveal to us. Only laptops or PCs made by nVidia have chips anymore so more than likely unless it's a laptop you have a video card by the way. ;)
We'll be watching for your file and anything else you can offer. Welcome!
Sincerely,
Phil
ThunfischXX
Postby ThunfischXX » Thu Apr 23, 2009 9:29 pm
here do u mean this? :
System Information
Time of this report: 4/23/2009, 23:26:26
Machine name: TIMOTHUN-PC
Operating System: Windows Vista™ Home Premium (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.090302-1506)
Language: German (Regional Setting: German)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP35-DS3R
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 3582MB RAM
Page File: 2334MB used, 5063MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DxDiag Version: 6.00.6001.18000 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GT
Manufacturer: NVIDIA
Chip type: GeForce 8800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_080110B0&REV_A2
Display Memory: 2544 MB
Dedicated Memory: 1009 MB
Shared Memory: 1535 MB
Current Mode: 1152 x 864 (32 bit) (60Hz)
Monitor: PnP-Monitor (Standard)
Driver Name: nvd3dum.dll,nvwgf2um.dll
Driver Version: 7.15.0011.8250 (English)
DDI Version: 10
Driver Date/Size: 3/27/2009 10:03:00, 6082560 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4551-11CF-3A53-0A2802C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0x080110B0
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Lautsprecher (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0885&SUBSYS_1458A002&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHDA.sys
Driver Version: 6.00.0001.5485 (English)
WHQL Logo'd: Yes
Date and Size: 9/19/2007 11:11:48, 1959832 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Realtek Digital Input (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x2939
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 1/21/2008 04:23:03, 194560 bytes
| Driver: usbd.sys, 1/21/2008 04:23:03, 5888 bytes
Gameport Devices
PS/2 Devices
+ PS/2 Keyboard
| Matching Device ID: *pnp0303
| Upper Filters: L8042Kbd
| Service: i8042prt
| Driver: L8042Kbd.sys, 2/29/2008 03:12:48, 20240 bytes
| Driver: i8042prt.sys, 1/21/2008 04:23:20, 54784 bytes
| Driver: kbdclass.sys, 1/21/2008 04:23:23, 35384 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Upper Filters: L8042mou, LMouKE
| Service: i8042prt
| Driver: L8042mou.Sys, 2/29/2008 03:12:56, 63120 bytes
| Driver: LMouKE.Sys, 2/29/2008 03:13:36, 79120 bytes
| Driver: KHALMNPR.Exe, 2/29/2008 03:12:38, 76304 bytes
| Driver: mouclass.sys, 1/21/2008 04:23:20, 34360 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 1/21/2008 04:23:01, 54328 bytes
| Driver: sermouse.sys, 1/21/2008 04:23:20, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 407.3 GB
Total Space: 953.9 GB
File System: NTFS
Model: SAMSUNG HD103UJ ATA Device
Drive: F:
Model: HL-DT-ST DVD-RAM GSA-H55L SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6001.18000 (German), 1/21/2008 04:23:02, 67072 bytes
Drive: E:
Model: HL-DT-ST DVDRAM GH20LS10 ATA Device
System Devices
Name: Intel(R) G33/G31/P35/P31 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_50001458&REV_02\3&13C0B0C5&2&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6001.18000 (German), 1/21/2008 04:23:01, 151096 bytes
Name: Intel(R) G33/G31/P35/P31 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_50001458&REV_02\3&13C0B0C5&2&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_50011458&REV_02\3&13C0B0C5&2&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_50011458&REV_02\3&13C0B0C5&2&E3
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_50011458&REV_02\3&13C0B0C5&2&E0
Name: High Definition Audio-Controller
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_A0021458&REV_02\3&13C0B0C5&2&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6001.17036 (English), 1/21/2008 04:23:22, 53760 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50061458&REV_02\3&13C0B0C5&2&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:03, 39424 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:03, 226304 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:03, 194560 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 11:46:05, 8704 bytes
Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/21/2008 04:23:03, 15872 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50061458&REV_02\3&13C0B0C5&2&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50041458&REV_02\3&13C0B0C5&2&D2
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:03, 23552 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50041458&REV_02\3&13C0B0C5&2&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50041458&REV_02\3&13C0B0C5&2&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50041458&REV_02\3&13C0B0C5&2&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50041458&REV_02\3&13C0B0C5&2&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50041458&REV_02\3&13C0B0C5&2&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50011458&REV_02\3&13C0B0C5&2&FB
Driver: n/a
Name: Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_B0021458&REV_02\3&13C0B0C5&2&FD
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:00, 16440 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6001.18000 (German), 1/21/2008 04:23:00, 45112 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:00, 21560 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6001.18000 (German), 1/21/2008 04:23:00, 110136 bytes
Name: Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_B0021458&REV_02\3&13C0B0C5&2&FA
Name: Intel(R) ICH9R LPC Interface Controller - 2916
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_50011458&REV_02\3&13C0B0C5&2&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/21/2008 04:23:01, 16440 bytes
Name: Intel(R) 82801 PCI-Brücke - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50001458&REV_92\3&13C0B0C5&2&F0
Name: GIGABYTE GBB36X Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&CACCF14&0&00E3
Driver: C:\Windows\system32\DRIVERS\jraid.sys, 1.17.0028.0000 (English), 9/29/2007 07:30:52, 65024 bytes
Name: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_01\4&2EA914C&0&00E4
Driver: C:\Windows\system32\DRIVERS\Rtlh86.sys, 6.200.1130.2007 (English), 12/6/2007 06:50:50, 103424 bytes
and thank you all you are very kind ^^
ThunfischXX
Postby ThunfischXX » Thu Apr 23, 2009 9:32 pm
first sorry for double post but i just can take here 35k letters so here is the rest :
Name: NVIDIA GeForce 8800 GT
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_080110B0&REV_A2\4&39BD1753&0&0008
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 7738816 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 4160 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 6082560 bytes
Driver: C:\Windows\system32\nvapi.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 667648 bytes
Driver: C:\Windows\system32\nvcuda.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 1560576 bytes
Driver: C:\Windows\system32\nvwgf2um.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 2742784 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 401408 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 9945088 bytes
Driver: C:\Windows\system32\nvsvs.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 1277952 bytes
Driver: C:\Windows\system32\nvsvsr.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 1347584 bytes
Driver: C:\Windows\system32\nvcpl.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 13687328 bytes
Driver: C:\Windows\system32\nvsvcr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 958464 bytes
Driver: C:\Windows\system32\nvsvc.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 641568 bytes
Driver: C:\Windows\system32\nvmctray.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 92704 bytes
Driver: C:\Windows\system32\nvdisps.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 4717088 bytes
Driver: C:\Windows\system32\nvdispsr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 6593056 bytes
Driver: C:\Windows\system32\nvgames.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 3496480 bytes
Driver: C:\Windows\system32\nvgamesr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 4287008 bytes
Driver: C:\Windows\system32\nvmccss.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 195104 bytes
Driver: C:\Windows\system32\nvmccssr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 465440 bytes
Driver: C:\Windows\system32\nvmobls.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 1280544 bytes
Driver: C:\Windows\system32\nvmoblsr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 2861600 bytes
Driver: C:\Windows\system32\nvvitvs.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 3803680 bytes
Driver: C:\Windows\system32\nvvitvsr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 4287008 bytes
Driver: C:\Windows\system32\nvmccs.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 236064 bytes
Driver: C:\Windows\system32\nvmccsrs.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 45056 bytes
Driver: C:\Windows\system32\nvwss.dll, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 2751008 bytes
Driver: C:\Windows\system32\nvwssr.dll, 7.15.0011.8250 (German), 3/27/2009 10:03:00, 3033632 bytes
Driver: C:\Windows\system32\NvPVEnc.ax, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 1253376 bytes
Driver: C:\Windows\system32\nvudisp.exe, 1.03.0022.0002 (English), 3/27/2009 10:03:00, 453152 bytes
Driver: C:\Windows\system32\nvvsvc.exe, 7.15.0011.8250 (English), 3/27/2009 10:03:00, 207392 bytes
Driver: C:\Windows\system32\nvwsapps.xml, 3/27/2009 10:03:00, 47360 bytes
Driver: C:\Windows\system32\nvapps.xml, 3/27/2009 10:03:00, 215465 bytes
Driver: C:\Windows\system32\nvdisp.nvu, 3/27/2009 10:03:00, 9694 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (German), 1/8/2008 19:53:00, 795104 bytes
Driver: C:\Windows\help\nvcpl\nvdsp.chm, 3/27/2009 10:03:00, 187817 bytes
Driver: C:\Windows\help\nvcpl\nv3d.chm, 3/27/2009 10:03:00, 123842 bytes
Driver: C:\Windows\help\nvcpl\nvmob.chm, 1/8/2008 19:53:00, 54988 bytes
Driver: C:\Windows\help\nvcpl\nvwks.chm, 3/27/2009 10:03:00, 261806 bytes
Driver: C:\Windows\help\nvcpl\nvcplara.chm, 3/27/2009 10:03:00, 126836 bytes
Driver: C:\Windows\help\nvcpl\nvdspara.chm, 3/27/2009 10:03:00, 213561 bytes
Driver: C:\Windows\help\nvcpl\nv3dara.chm, 3/27/2009 10:03:00, 148965 bytes
Driver: C:\Windows\help\nvcpl\nvmobara.chm, 3/27/2009 10:03:00, 54873 bytes
Driver: C:\Windows\help\nvcpl\nvcplcsy.chm, 3/27/2009 10:03:00, 128345 bytes
Driver: C:\Windows\help\nvcpl\nvdspcsy.chm, 3/27/2009 10:03:00, 220062 bytes
Driver: C:\Windows\help\nvcpl\nv3dcsy.chm, 3/27/2009 10:03:00, 143406 bytes
Driver: C:\Windows\help\nvcpl\nvmobcsy.chm, 3/27/2009 10:03:00, 54914 bytes
Driver: C:\Windows\help\nvcpl\nvcpldan.chm, 3/27/2009 10:03:00, 122697 bytes
Driver: C:\Windows\help\nvcpl\nvdspdan.chm, 3/27/2009 10:03:00, 198420 bytes
Driver: C:\Windows\help\nvcpl\nv3ddan.chm, 3/27/2009 10:03:00, 126080 bytes
Driver: C:\Windows\help\nvcpl\nvmobdan.chm, 3/27/2009 10:03:00, 53569 bytes
Driver: C:\Windows\help\nvcpl\nvcpldeu.chm, 3/27/2009 10:03:00, 125728 bytes
Driver: C:\Windows\help\nvcpl\nvdspdeu.chm, 3/27/2009 10:03:00, 209448 bytes
Driver: C:\Windows\help\nvcpl\nv3ddeu.chm, 3/27/2009 10:03:00, 133026 bytes
Driver: C:\Windows\help\nvcpl\nvmobdeu.chm, 3/27/2009 10:03:00, 54364 bytes
Driver: C:\Windows\help\nvcpl\nvcplell.chm, 3/27/2009 10:03:00, 129400 bytes
Driver: C:\Windows\help\nvcpl\nvdspell.chm, 3/27/2009 10:03:00, 237264 bytes
Driver: C:\Windows\help\nvcpl\nv3dell.chm, 3/27/2009 10:03:00, 148194 bytes
Driver: C:\Windows\help\nvcpl\nvmobell.chm, 3/27/2009 10:03:00, 56222 bytes
Driver: C:\Windows\help\nvcpl\nvcpleng.chm, 3/27/2009 10:03:00, 123592 bytes
Driver: C:\Windows\help\nvcpl\nvdspeng.chm, 3/27/2009 10:03:00, 190394 bytes
Driver: C:\Windows\help\nvcpl\nv3deng.chm, 3/27/2009 10:03:00, 124309 bytes
Driver: C:\Windows\help\nvcpl\nvmobeng.chm, 3/27/2009 10:03:00, 55066 bytes
Driver: C:\Windows\help\nvcpl\nvcplesn.chm, 3/27/2009 10:03:00, 125324 bytes
Driver: C:\Windows\help\nvcpl\nvdspesn.chm, 3/27/2009 10:03:00, 205689 bytes
Driver: C:\Windows\help\nvcpl\nv3desn.chm, 3/27/2009 10:03:00, 136389 bytes
Driver: C:\Windows\help\nvcpl\nvmobesn.chm, 3/27/2009 10:03:00, 53690 bytes
Driver: C:\Windows\help\nvcpl\nvcplesm.chm, 3/27/2009 10:03:00, 126330 bytes
Driver: C:\Windows\help\nvcpl\nvdspesm.chm, 3/27/2009 10:03:00, 205569 bytes
Driver: C:\Windows\help\nvcpl\nv3desm.chm, 3/27/2009 10:03:00, 134544 bytes
Driver: C:\Windows\help\nvcpl\nvmobesm.chm, 3/27/2009 10:03:00, 53896 bytes
Driver: C:\Windows\help\nvcpl\nvcplfin.chm, 3/27/2009 10:03:00, 126192 bytes
Driver: C:\Windows\help\nvcpl\nvdspfin.chm, 3/27/2009 10:03:00, 212482 bytes
Driver: C:\Windows\help\nvcpl\nv3dfin.chm, 3/27/2009 10:03:00, 143276 bytes
Driver: C:\Windows\help\nvcpl\nvmobfin.chm, 3/27/2009 10:03:00, 54573 bytes
Driver: C:\Windows\help\nvcpl\nvcplfra.chm, 3/27/2009 10:03:00, 125455 bytes
Driver: C:\Windows\help\nvcpl\nvdspfra.chm, 3/27/2009 10:03:00, 208714 bytes
Driver: C:\Windows\help\nvcpl\nv3dfra.chm, 3/27/2009 10:03:00, 136977 bytes
Driver: C:\Windows\help\nvcpl\nvmobfra.chm, 3/27/2009 10:03:00, 54134 bytes
Driver: C:\Windows\help\nvcpl\nvcplheb.chm, 3/27/2009 10:03:00, 128351 bytes
Driver: C:\Windows\help\nvcpl\nvdspheb.chm, 3/27/2009 10:03:00, 219892 bytes
Driver: C:\Windows\help\nvcpl\nv3dheb.chm, 3/27/2009 10:03:00, 142318 bytes
Driver: C:\Windows\help\nvcpl\nvmobheb.chm, 3/27/2009 10:03:00, 56374 bytes
Driver: C:\Windows\help\nvcpl\nvcplhun.chm, 3/27/2009 10:03:00, 127434 bytes
Driver: C:\Windows\help\nvcpl\nvdsphun.chm, 3/27/2009 10:03:00, 216830 bytes
Driver: C:\Windows\help\nvcpl\nv3dhun.chm, 3/27/2009 10:03:00, 150020 bytes
Driver: C:\Windows\help\nvcpl\nvmobhun.chm, 3/27/2009 10:03:00, 55411 bytes
Driver: C:\Windows\help\nvcpl\nvcplita.chm, 3/27/2009 10:03:00, 126062 bytes
Driver: C:\Windows\help\nvcpl\nvdspita.chm, 3/27/2009 10:03:00, 216229 bytes
Driver: C:\Windows\help\nvcpl\nv3dita.chm, 3/27/2009 10:03:00, 137339 bytes
Driver: C:\Windows\help\nvcpl\nvmobita.chm, 3/27/2009 10:03:00, 54306 bytes
Driver: C:\Windows\help\nvcpl\nvcpljpn.chm, 3/27/2009 10:03:00, 131222 bytes
Driver: C:\Windows\help\nvcpl\nvdspjpn.chm, 3/27/2009 10:03:00, 257220 bytes
Driver: C:\Windows\help\nvcpl\nv3djpn.chm, 3/27/2009 10:03:00, 160961 bytes
Driver: C:\Windows\help\nvcpl\nvmobjpn.chm, 3/27/2009 10:03:00, 57879 bytes
Driver: C:\Windows\help\nvcpl\nvcplkor.chm, 3/27/2009 10:03:00, 126001 bytes
Driver: C:\Windows\help\nvcpl\nvdspkor.chm, 3/27/2009 10:03:00, 240560 bytes
Driver: C:\Windows\help\nvcpl\nv3dkor.chm, 3/27/2009 10:03:00, 150775 bytes
Driver: C:\Windows\help\nvcpl\nvmobkor.chm, 3/27/2009 10:03:00, 56283 bytes
Driver: C:\Windows\help\nvcpl\nvcplnld.chm, 3/27/2009 10:03:00, 125469 bytes
Driver: C:\Windows\help\nvcpl\nvdspnld.chm, 3/27/2009 10:03:00, 202598 bytes
Driver: C:\Windows\help\nvcpl\nv3dnld.chm, 3/27/2009 10:03:00, 130571 bytes
Driver: C:\Windows\help\nvcpl\nvmobnld.chm, 3/27/2009 10:03:00, 53806 bytes
Driver: C:\Windows\help\nvcpl\nvcplnor.chm, 3/27/2009 10:03:00, 122866 bytes
Driver: C:\Windows\help\nvcpl\nvdspnor.chm, 3/27/2009 10:03:00, 206705 bytes
Driver: C:\Windows\help\nvcpl\nv3dnor.chm, 3/27/2009 10:03:00, 135122 bytes
Driver: C:\Windows\help\nvcpl\nvmobnor.chm, 3/27/2009 10:03:00, 54029 bytes
Driver: C:\Windows\help\nvcpl\nvcplplk.chm, 3/27/2009 10:03:00, 127261 bytes
Driver: C:\Windows\help\nvcpl\nvdspplk.chm, 3/27/2009 10:03:00, 219774 bytes
Driver: C:\Windows\help\nvcpl\nv3dplk.chm, 3/27/2009 10:03:00, 147679 bytes
Driver: C:\Windows\help\nvcpl\nvmobplk.chm, 3/27/2009 10:03:00, 55250 bytes
Driver: C:\Windows\help\nvcpl\nvcplptg.chm, 3/27/2009 10:03:00, 125300 bytes
Driver: C:\Windows\help\nvcpl\nvdspptg.chm, 3/27/2009 10:03:00, 209666 bytes
Driver: C:\Windows\help\nvcpl\nv3dptg.chm, 3/27/2009 10:03:00, 138742 bytes
Driver: C:\Windows\help\nvcpl\nvmobptg.chm, 3/27/2009 10:03:00, 53887 bytes
Driver: C:\Windows\help\nvcpl\nvcplptb.chm, 3/27/2009 10:03:00, 124360 bytes
Driver: C:\Windows\help\nvcpl\nvdspptb.chm, 3/27/2009 10:03:00, 204260 bytes
Driver: C:\Windows\help\nvcpl\nv3dptb.chm, 3/27/2009 10:03:00, 135432 bytes
Driver: C:\Windows\help\nvcpl\nvmobptb.chm, 3/27/2009 10:03:00, 54058 bytes
Driver: C:\Windows\help\nvcpl\nvcplrus.chm, 3/27/2009 10:03:00, 127228 bytes
Driver: C:\Windows\help\nvcpl\nvdsprus.chm, 3/27/2009 10:03:00, 216053 bytes
Driver: C:\Windows\help\nvcpl\nv3drus.chm, 3/27/2009 10:03:00, 143430 bytes
Driver: C:\Windows\help\nvcpl\nvmobrus.chm, 3/27/2009 10:03:00, 54865 bytes
Driver: C:\Windows\help\nvcpl\nvcplsky.chm, 3/27/2009 10:03:00, 126379 bytes
Driver: C:\Windows\help\nvcpl\nvdspsky.chm, 3/27/2009 10:03:00, 224400 bytes
Driver: C:\Windows\help\nvcpl\nv3dsky.chm, 3/27/2009 10:03:00, 145563 bytes
Driver: C:\Windows\help\nvcpl\nvmobsky.chm, 3/27/2009 10:03:00, 55233 bytes
Driver: C:\Windows\help\nvcpl\nvcplslv.chm, 3/27/2009 10:03:00, 129348 bytes
Driver: C:\Windows\help\nvcpl\nvdspslv.chm, 3/27/2009 10:03:00, 218727 bytes
Driver: C:\Windows\help\nvcpl\nv3dslv.chm, 3/27/2009 10:03:00, 142985 bytes
Driver: C:\Windows\help\nvcpl\nvmobslv.chm, 3/27/2009 10:03:00, 55550 bytes
Driver: C:\Windows\help\nvcpl\nvcplsve.chm, 3/27/2009 10:03:00, 123625 bytes
Driver: C:\Windows\help\nvcpl\nvdspsve.chm, 3/27/2009 10:03:00, 200268 bytes
Driver: C:\Windows\help\nvcpl\nv3dsve.chm, 3/27/2009 10:03:00, 134544 bytes
Driver: C:\Windows\help\nvcpl\nvmobsve.chm, 3/27/2009 10:03:00, 53715 bytes
Driver: C:\Windows\help\nvcpl\nvcpltha.chm, 3/27/2009 10:03:00, 128551 bytes
Driver: C:\Windows\help\nvcpl\nvdsptha.chm, 3/27/2009 10:03:00, 236116 bytes
Driver: C:\Windows\help\nvcpl\nv3dtha.chm, 3/27/2009 10:03:00, 154439 bytes
Driver: C:\Windows\help\nvcpl\nvmobtha.chm, 3/27/2009 10:03:00, 56597 bytes
Driver: C:\Windows\help\nvcpl\nvcpltrk.chm, 3/27/2009 10:03:00, 122998 bytes
Driver: C:\Windows\help\nvcpl\nvdsptrk.chm, 3/27/2009 10:03:00, 211730 bytes
Driver: C:\Windows\help\nvcpl\nv3dtrk.chm, 3/27/2009 10:03:00, 139511 bytes
Driver: C:\Windows\help\nvcpl\nvmobtrk.chm, 3/27/2009 10:03:00, 55266 bytes
Driver: C:\Windows\help\nvcpl\nvcplchs.chm, 3/27/2009 10:03:00, 125271 bytes
Driver: C:\Windows\help\nvcpl\nvdspchs.chm, 3/27/2009 10:03:00, 226411 bytes
Driver: C:\Windows\help\nvcpl\nv3dchs.chm, 3/27/2009 10:03:00, 142995 bytes
Driver: C:\Windows\help\nvcpl\nvmobchs.chm, 3/27/2009 10:03:00, 55822 bytes
Driver: C:\Windows\help\nvcpl\nvcplcht.chm, 3/27/2009 10:03:00, 125851 bytes
Driver: C:\Windows\help\nvcpl\nvdspcht.chm, 3/27/2009 10:03:00, 230731 bytes
Driver: C:\Windows\help\nvcpl\nv3dcht.chm, 3/27/2009 10:03:00, 148839 bytes
Driver: C:\Windows\help\nvcpl\nvmobcht.chm, 3/27/2009 10:03:00, 56394 bytes
Driver: C:\Windows\nvtmpinst\nvcpl.cpl, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvcplui.exe, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvcpluir.dll, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvcpl.chm, , 0 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.04.0002.0037 (English), 3/27/2009 10:03:00, 139264 bytes
Driver: C:\Windows\system32\nvcod141.dll, 1.04.0002.0037 (English), 3/27/2009 10:03:00, 139264 bytes
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.10.0005.0000
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.10.0005.0000
Full Screen Renderer,0x00200000,1,0,,6.06.6001.18063
CoreAVC Video Decoder,0x00600000,1,1,AVCDX.ax,0.00.0000.0004
Dirac Source,0x00600000,0,0,DiracSplitter.ax,1.00.0000.0000
Matroska Source,0x00600000,0,0,MatroskaDX.ax,1.00.0002.0009
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.10.0005.0000
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.10.0005.0000
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.10.0005.0000
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Matroska Splitter,0x00600000,1,1,MatroskaDX.ax,1.00.0002.0009
Color Space Converter,0x00400001,1,1,,6.06.6001.18063
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6001.18063
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6001.18063
RadLight Ogg Splitter,0x00800101,1,1,RLOgg.ax,1.00.0000.0002
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7000
RadLight Vorbis Decoder,0x00800001,1,1,RLVorbisDec.ax,1.00.0000.0002
RealVideo Decoder,0x00400000,1,1,RealMediaDX.ax,1.00.0001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6001.18177
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6001.18000
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6001.18000
Nero Resize,0x00400000,1,1,NeResize.ax,4.10.0005.0000
MJPEG Decompressor,0x00600000,1,1,,6.06.6001.18063
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6001.18177
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6001.18063
MPEG-2 PSI Reader Filter,0x00200000,0,0,Mpeg2PsiReader.ax,1.00.0000.0004
SAMI (CC) Parser,0x00400000,1,1,,6.06.6001.18063
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.10.0005.0000
Dump,0x00200000,1,0,dump.ax,1.00.0000.0000
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6001.18177
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
WAV Dest,0x00200000,0,0,wavdest.ax,
AAC Parser,0x00400000,1,1,aac_parser.ax,1.01.0000.0000
RadLight APE DirectShow Filter,0x00600000,0,1,RLAPEDec.ax,1.00.0000.0000
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.10.0005.0000
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.10.0005.0000
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.10.0005.0000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.10.0005.0000
FLV Splitter,0x00600000,1,1,flvDX.dll,1.00.0000.0001
Internal Script Command Renderer,0x00800001,1,0,,6.06.6001.18063
MPEG Audio Decoder,0x03680001,1,1,,6.06.6001.18063
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.10.0005.0000
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.10.0005.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.10.0005.0000
DV Splitter,0x00600000,1,2,,6.06.6001.18000
Nero Video Decoder HD,0x00400000,1,2,nevideohd.ax,4.10.0005.0000
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.10.0005.0000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6001.18063
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.10.0005.0000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.06.0087.0020
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.06.0087.0020
Dirac Splitter,0x00600000,1,1,DiracSplitter.ax,1.00.0000.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.10.0005.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.10.0005.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
MPEG-2 Stream Reader Filter,0x00200000,0,0,Mpeg2StreamReader.ax,1.04.0000.0000
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.10.0005.0000
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.10.0005.0000
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.10.0005.0000
ACM Wrapper,0x00600000,1,1,,6.06.6001.18063
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0575
Video Renderer,0x00800001,1,0,,6.06.6001.18063
Nero DVD Navigator,0x00600000,0,14,nedvd.ax,4.10.0005.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6001.18000
Ogg Source,0x00600001,0,0,oggsplitter.ax,1.00.0000.0000
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6001.18000
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.10.0005.0000
Video Port Manager,0x00600000,2,1,,6.06.6001.18063
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,8.01.0000.0094
Video Renderer,0x00400000,1,0,,6.06.6001.18063
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.10.0005.0000
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaDX.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.10.0005.0000
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.03.0000.0084
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
FLV Video Decoder,0x00600000,1,1,flvDX.dll,1.00.0000.0001
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.10.0005.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
Nero Audio Decoder 2,0x00600000,1,1,neaudio2.ax,4.10.0005.0000
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,1.00.0000.0004
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Nero FLV Splitter,0x00600000,1,1,NeFLVSplitter.ax,4.10.0005.0000
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.10.0005.0000
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.10.0005.0000
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.06.0087.0020
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.00.0001.0003
RealAudio Decoder,0x00400000,1,1,RealMediaDX.ax,1.00.0001.0001
Avi Splitter,0x00600001,1,1,AviSplitter.ax,1.00.0000.0007
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.00.0001.0003
DVD Navigator,0x00200000,0,3,,6.06.6001.18000
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Ogg Splitter,0x00600001,1,1,oggsplitter.ax,1.00.0000.0000
Overlay Mixer2,0x00200000,1,1,,6.06.6001.18000
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.06.0087.0020
RadLight Speex Decoder,0x00600000,1,1,RLSpeexDec.ax,1.00.0000.0000
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.10.0005.0000
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.10.0005.0000
DivX MKV Demux,0x00200000,0,1,DMFSource.ax,1.00.0000.0047
AC3Filter,0x40000000,1,1,ac3DX.ax,1.00.0001.0000
AVI Draw,0x00600064,9,1,,6.06.6001.18063
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.10.0005.0000
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6001.18177
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.10.0005.0000
Nero Video Decoder,0x00600000,2,1,nevideo.ax,4.10.0005.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6001.18000
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6001.18000
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.10.0005.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6001.18000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.10.0005.0000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
FLV Source,0x00600000,0,0,flvDX.dll,1.00.0000.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6001.18000
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.10.0005.0000
Overlay Mixer,0x00200000,0,0,,6.06.6001.18000
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.10.0005.0000
Avi Source,0x00600001,0,0,AviSplitter.ax,1.00.0000.0007
AVI Decompressor,0x00600000,1,1,,6.06.6001.18063
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
AVI/WAV File Source,0x00400000,0,2,,6.06.6001.18063
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6001.18063
MIDI Parser,0x00400000,1,1,,6.06.6001.18063
Multi-file Parser,0x00400000,1,1,,6.06.6001.18063
File stream renderer,0x00400000,1,1,,6.06.6001.18063
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.10.0005.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.10.0005.0000
A/V Dummy Filter,0x00200000,1,0,SmabT.spk,
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.10.0005.0000
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.10.0005.0000
Nero DVD Decoder,0x00600000,2,1,nevideo.ax,4.10.0005.0000
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
EssienR&D MPEG Writer Filter,0x00200000,2,0,mpgfiltr.ax,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.10.0005.0000
RealMedia Splitter,0x00600000,1,1,RealMediaDX.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6001.18063
File Source (Async.),0x00400000,0,1,,6.06.6001.18063
File Source (URL),0x00400000,0,1,,6.06.6001.18063
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6001.18177
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,4.10.0005.0000
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
RadLight Theora Decoder,0x00600000,1,1,RLTheoraDec.ax,1.00.0000.0003
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.10.0005.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.06.0087.0020
Dirac Video Decoder,0x00400000,1,1,DiracSplitter.ax,1.00.0000.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.10.0005.0000
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.10.0005.0000
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6001.18000
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6001.18177
MPEG Video Decoder,0x40000001,1,1,,6.06.6001.18063
WDM Streaming-Tee/Splitter-Geräte:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6001.18063
Cinepak Codec von Radius,0x00200000,1,1,,6.06.6001.18000
DivX 6.8.5 Codec (4 Logical CPUs),0x00200000,1,1,,6.06.6001.18000
Helix I420 YUV Codec,0x00200000,1,1,,6.06.6001.18000
Intel IYUV Codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
Xfire Video Codec,0x00200000,1,1,,6.06.6001.18000
Helix YV12 YUV Codec,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,,6.06.6001.18063
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,,6.06.6001.18063
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,,6.06.6001.18063
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,,6.06.6001.18063
IMA ADPCM,0x00200000,1,1,,6.06.6001.18063
Microsoft ADPCM,0x00200000,1,1,,6.06.6001.18063
GSM 6.10,0x00200000,1,1,,6.06.6001.18063
CCITT A-Law,0x00200000,1,1,,6.06.6001.18063
CCITT u-Law,0x00200000,1,1,,6.06.6001.18063
MPEG Layer-3,0x00200000,1,1,,6.06.6001.18063
Audio Capture Sources:
Realtek Digital Input (Realtek ,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6001.18063
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6001.18063
WDM Streaming-Capturegeräte:
Realtek HD Digital input,0x00200000,1,1,,6.00.6001.18000
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming-Wiedergabegeräte:
Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
Realtek HDA SPDIF Out,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6001.18177
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6001.18177
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6001.18000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6001.18177
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6001.18177
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6001.18177
WDM Streaming-Kommunikations-Transforms:
Audio Renderers:
Lautsprecher (Realtek High Defi,0x00200000,1,0,,6.06.6001.18063
Default DirectSound Device,0x00800000,1,0,,6.06.6001.18063
Default WaveOut Device,0x00200000,1,0,,6.06.6001.18063
DirectSound: Lautsprecher (Realtek High Definition Audio),0x00200000,1,0,,6.06.6001.18063
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6001.18063
Realtek Digital Output (Realtek,0x00200000,1,0,,6.06.6001.18063
i hope it is usefull :)
and thank you all very very very much for your work
Phil Walker
Well...
Postby Phil Walker » Thu Apr 23, 2009 10:25 pm
This is what was needed, but not in the correct format (at least for me). It would have been better if you would have uploaded the whole file using the Additional Options below the text editor window rather than copying and pasting it into a post. It will take me some time to decipher in this way, but I will do my best. Know it will take some time though and you should thus not expect an immediate reply compared to if I had the file in a more visible format.
Sincerely,
Phil
Postby Keith » Fri Apr 24, 2009 1:12 am
Yes, as Phil indicated that is basically what we wanted.
The board does take text file (.txt) attachments. Instead of copying the information and pasting it into a huge post you could have just attached the original document file to your reply using the method I described above.
My first suggestion is that you get and install a newer mouse driver from your mouse manufacturer. The one you have installed is older than mine.
Be sure you follow your mouse maker's driver install proceedure.
What screen resolution do you have your game set for? If it is 1152 x 864, you may have to try something else like 1280x1024.
In the Caesar IV game Video Settings menu, turn Vertical Sync off (un-check the box) if you have it on.
Also, try lowering the Anti-aliasing settings if you are using a high setting like 6x or 4x.
If your mouse has a utility program running in the system background or the system tray in the lower right corner disable it and try the game without it running.
Phil, I have copied his dxdiag to a the attached file so you can do what you need to do to it so you can read it easily.
Phil Walker
More...
Postby Phil Walker » Fri Apr 24, 2009 4:09 am
Thanks Keith! Did make it easier. You do have a video card and some drivers I have not yet seen, but I'll be getting in touch with nVidia tomorrow to see what versions are approved since I stopped some time ago, but will start verifying again. While what Keith said is all true save the mouse prgram is not usually a problems as it is not with mine. You have two even more severe problems. Those being;
1. You have WAY too much running in the background. However...
1. (Worse!) You have one of those lousy virtual drive programs on your system that I'm sure SecuROM has caught. This gives you two options, The game OR the virtual drive AND the program that created it. You cannot have both and have the game work properly if at all. Get RID of them and I do mean off your system entirely. It is obvious as you have no D drive and your media drives are out of sequence not indicated one is an add-on as well as one stating it is a "SCSI" device.
So, I'm sorry to be so blunt about this but we know that the game has SecuROM which seeks these drives and programs out and once found, the game will never work properly if at all once it finds them. SecuROM is the copy-protection built into the game itself so there is no way around this. Sorry! :(
Sincerely,
Phil
ThunfischXX
Postby ThunfischXX » Fri Apr 24, 2009 11:05 am
mhm okay thank you very much ill try this all :)
just one more question how can i cancel the most procees ???
or the things you mean
Thunfisch
Phil Walker
Happy to Explain
Postby Phil Walker » Fri Apr 24, 2009 12:03 pm
In regard to what I've mentioned, first open My Computer. Locate the virtual drives you know are not part of your original system. If more than one, one at a time, right click on the drive and select Disable/Uninstall. This will disalbe the drives.
As to the program(s) that created it/them, you need to open Control Panel and then open Add or Remove Programs. Locate the programs and uninstall them using Remove or Change buttons. You will need to reboot your system for the programs and drives to be completely removed.
As to the background programs, they are located in "msconfig" a dos program. You access it by clicking on Start and selecting Run. When the window appears type in "msconfig" (without the quotes) and either click the OK button or depress your Enter key. The program will load and a window will appear. When the window appears click on the Startup tab. BE CAREFUL! Some of these are needed but surely not all of them. You will need your Anti-Virus and Firewall programs as well as the nVidia program that contains the driver number within it. None of the others though. You can keep your custom mouse and any messenger programs you use, but uncheck all else. Then click Apply and click Close. After closign a new window will appear. Make sure to close all other windows then click the Restart button on that window. You will reboot. After reboot and getting back onto your account you will encounter a pop-up window. Put a check in the Do Not Show Me This Again box and click the OK button. If you would like assistance I'll be happy to help, but you will need to remove the virtual drives and progarm(s) first and then I'll instruct so I can advise.
Will look for your next reply. Good Luck! ;)
Sincerely,
Phil
ThunfischXX
Postby ThunfischXX » Fri Apr 24, 2009 1:01 pm
thank you,
but i have a question could i just re install windows vista and clean my disc space?
maybe that can help me???
Phil Walker
Yes and No
Postby Phil Walker » Fri Apr 24, 2009 1:19 pm
Re-installing Vista is a bit severe. It will help but only with the virtual drives and the programs. The rest will come back due most likely to Windows Updates and other things you install. This does not include the time it will take to do all of this. So, I won't suggest it, but it's your decision.
Sincerely,
Phil
ThunfischXX
thank you all
Postby ThunfischXX » Fri Apr 24, 2009 8:47 pm
mhmk
i ll try it mhm i ll be finished tomorrow morning or so :D
whenn it don't work i ll post it here when it work i ll say sth. and thank you all for your work^^
Phil Walker
Good Enough
Postby Phil Walker » Fri Apr 24, 2009 10:36 pm
Keep us posted, good luck, and hopeful happy gaming!
Sincerely,
Phil
Postby Keith » Mon Apr 27, 2009 12:27 am
Well, I wonder if he's got it fixed or not.
Phil Walker
Who Knows?!
Postby Phil Walker » Mon Apr 27, 2009 3:39 am
I don't know, but I did see him viewing this thread again yesterday morning though, so maybe he was going over the stpes and by now he's enjoying the game. We can hope so anyway. ;)
Sincerely,
Phil
ThunfischXX
It works
Postby ThunfischXX » Sun May 03, 2009 6:28 pm
sorry for my late post but the inernet in my town became new now we have a faster one^^
but at the end it works :D :D :D
but i don't know what the problem was :S
thank you all very much for your hellp^^
I am so happy ^^
