Primetime's Super Zoom
MidrealmDM70
Postby MidrealmDM70 » Sat May 22, 2010 3:55 pm
I am posting a Mod I use all the time, it allows you to change your camera angles in the game to zoom in extremely close or extremely far away.
I DID NOT CREATE THIS MOD
But props to Primetime whoever and wherever he or she is.
Once installed go to your video settings in the game and you should have more options avaialable for you camera angle.
On slow performance machines, extreme zoom-outs can cause slowdown,
particularly if you have alot of fog, smog, traffic, neon, etc.
Hope you enjoy it as much as I do.
Poe2008
Postby Poe2008 » Sun May 23, 2010 3:49 am
This is defiantly a must have MOD!
cynicalsim
Postby cynicalsim » Thu Jul 12, 2012 2:16 am
So very sorry to bring up a dead thread, but I thought it would be better than posting a new one. Would this mod happen to be available for download anywhere else? This link doesn't seem to be working. Thanks!
pcgamer2
Postby pcgamer2 » Sun Jul 15, 2012 3:19 am
The link doesn't work because it is believed that since TM switched the forum to the cloud that the forum no longer has access to the file server. Luckily for you I found the file on my external hard drive, so here you are https://rapidshare.com/files/306263624/SuperZoom.SCSPack
meredi
Postby meredi » Sat Jan 12, 2013 3:23 pm
i came here from google for that mod :/
tobing
Postby tobing » Sat Jan 12, 2013 6:08 pm
I have uploaded the file recently to SykDrive, try the link here:
http://tiltedmill.com/forums/showpost.php?p=283345&postcount=16
Quantum Reality
Postby Quantum Reality » Sat Sep 28, 2013 2:10 am
"tobing" wrote:I have uploaded the file recently to SykDrive, try the link here:
Hey,
I can't sign into SkyDrive - any way you can re-attach it to a forum post?
Or can you explain how to manually adjust the zoom settings?
Postby Keith » Sat Sep 28, 2013 5:19 am
Can't help you with SCS directions, as I don't have the game, but if you just click on the link in that other post it should open that user's SkyDrive folder. It's in his public folders so anyone can get in and you don't need to login/signin on SkyDrive to do it.
I just tried the link myself and the file window pops right up. Right click on the filename and select Download.
Quantum Reality
Postby Quantum Reality » Sat Sep 28, 2013 5:45 am
Nope. I tried right-click, Download --
It asked me for my SkyDrive login.
tobing
Postby tobing » Sat Sep 28, 2013 6:41 am
Hm, I didn't change anything and the file should be available. Posting the link again:
https://skydrive.live.com/redir?resid=80DE375F3F64E7E5!112&authkey=!AGRd5Ulm75ak5tE
Postby Keith » Sat Sep 28, 2013 8:21 am
If that link doesn't work try it from this Cloud server I uploaded the file to:
MEGA
Sarellion
Postby Sarellion » Sat Sep 28, 2013 8:30 am
Are the Haunted City buildings from TM included? According to what I ´ve read here, they are part of it. But it seems I can´t find them. I am a bit reluctant to activate every mod.
Postby Keith » Sat Sep 28, 2013 8:44 am
You can see what is in the file here:
http://tiltedmill.com/forums/showthread.php?t=26938
Sarellion
Postby Sarellion » Sat Sep 28, 2013 10:01 am
The problem I have is that it´s indicated the stuff is there but I don´t know what mod it is exactly.
People asked here:
http://tiltedmill.com/forums/showthread.php?t=27259
And more or less the same problem here:
http://tiltedmill.com/forums/showthread.php?t=26119
So yeah, i read Oh it´s there but well, I don´t know the name. It´s not Creepy Nightmare AFAIK
Quantum Reality
Postby Quantum Reality » Mon Oct 21, 2013 12:30 am
The Super Zoom Mod doesn't seem to be available, but anyhoo -
I *think* I can accomplish the same effect with this for the CameraSettings.xml file,
Code: Select all
<Camera_Settings_Table>
<Camera_Mode name="CAMERA_TYPE_5_EXTREME" EdgeBuffer="0" cpu="2.6" mem="2000" >
   <!-- Minimum and maximum distance of camera from ground  -->
   <Height min="2" max="120" />
   <!-- Minimum and maximum camera zoom  -->
   <Zoom min="2" max="120" />
   <!-- Minimum and maximum pitch of camera  -->
   <Pitch min="-1" max="89" />
</Camera_Mode>
<Camera_Mode name="CAMERA_TYPE_4_FREE" EdgeBuffer="0" cpu="2.6" mem="1500" >
   <Height min="2" max="60" />
   <Zoom min="2" max="60" />
</Camera_Mode>
<Camera_Mode name="CAMERA_TYPE_3_NORMAL" EdgeBuffer="0" cpu="2.1" mem="600">
   <Height min="2" max="55" />
   <Zoom min="2" max="55" />
   <Pitch min="-38" max="85" />
</Camera_Mode>
<Camera_Mode name="CAMERA_TYPE_2_SUBNORMAL" EdgeBuffer="0" AllowFireworks="false" cpu="2.1" mem="599">
   <Height min="2" max="40" />
   <Zoom min="2" max="40" />
   <Pitch min="-40" max="75" />
   <!-- Edge Buffer  -->
</Camera_Mode>
<Camera_Mode name="CAMERA_TYPE_1_RESTRICTED" EdgeBuffer="0" AllowFireworks="false">
   <Height min="2" max="28" />
   <Zoom min="2" max="28" />
   <Pitch min="-50" max="70" />
</Camera_Mode>
</Camera_Settings_Table>
And then adding this to the languagetext.xml file:
Code: Select all
  <String id="CAMERA_TYPE_LABLE">Camera Type</String>
  <String id="CAMERA_TYPE_1_RESTRICTED">Most Restricted</String>
  <String id="CAMERA_TYPE_2_SUBNORMAL">Restricted</String>
  <String id="CAMERA_TYPE_3_NORMAL">Normal</String>
  <String id="CAMERA_TYPE_4_FREE">Free</String>
  <String id="CAMERA_TYPE_5_EXTREME">Extreme</String>
  <String id="TT_CAMERA_TYPE">Choose the type of camera you want to use.\nChoose a more restricted camera type for better performance.</String>
  <String id="40200">Sound (Buildings)</String>
If anyone has guidelines to what cpu and mem actually mean/should be set at to optimize SCS's behavior when using the extreme camera, let me know please. :)
Last edited by Quantum Reality on Mon Oct 21, 2013 12:39 am, edited 1 time in total.
Sarellion
Postby Sarellion » Mon Oct 21, 2013 1:51 am
The Zoom Mod is in the package SCSDmoddistror on Skydrive. It´s called SuperZoom.
Return to “Mods (Files)”
