Basic Modding By Hand
Quantum Reality
Postby Quantum Reality » Sun Nov 17, 2013 2:37 am
Note all changes in bold. The following mods add/change:
- A camera that has some more freedom of movement than the "Free" Camera
- Building height offset that causes 'floaty' buildings is patched to make their heights look more reasonable on hilly ground
All directory names are relative to your Electronic Arts\SimCity Societies folder under Program Files (or Program Files (x86) depending on OS).
languagetext.xml
Stored in Localization\en-us
Code: Select all
  <String id="CAMERA_TYPE_4_FREE">Free</String>
  [b]<String id="CAMERA_TYPE_5_EXTREME">Extreme</String>[/b]
  <String id="TT_CAMERA_TYPE">Choose the type of camera you want to use.\nChoose a more restricted camera type for better perfo
CameraSettings.xml
Stored in Data\XMLDb\UI\CameraSettings
Code: Select all
<Camera_Settings_Table>
[b]<Camera_Mode name="CAMERA_TYPE_5_EXTREME" EdgeBuffer="0" cpu="2.6" mem="2000" >
   <!-- Minimum and maximum distance of camera from ground  -->
   <Height min="2" max="120" />
   <!-- Minimum and maximum camera zoom  -->
   <Zoom min="2" max="120" />
   <!-- Minimum and maximum pitch of camera  -->
   <Pitch min="-1" max="89" />
</Camera_Mode>[/b]
<Camera_Mode name="CAMERA_TYPE_4_FREE" EdgeBuffer="0" cpu="2.6" mem="1500" >
   <Height min="2" max="60" />
   <Zoom min="2" max="60" />
</Camera_Mode>
Constants.xml
Stored in Data\XMLDb\Constants
Code: Select all
 [b]   <Value type="float" name="BaseHeightIncrease">0.0</Value>[/b]
    <Placement>
TODO:
1. Figure out how to update VideoCards.xml under VideoSettings to add all the new cards developed since SCS came out. I'm not sure exactly what SimCity Societies queries to get the graphics card ID, but it obviously looks for a numeric brand code as judged from these lines:
Code: Select all
  <!--Supported ATI cards at time of release-->
  <Manufacturer name="ATI">
    <Series name="3870">
      <Settings default="high" camera="free"/>
 <!--Supported NVidia cards at time of release-->
  <Manufacturer name="NVIDIA">
    <Series name="9800">
2. Also, figure out how to extend building name and description changes depending on "mood". Right now not all of them get changed when the UI mood shifts, so you end up with rather ridiculous things like Cube Apartments still insisting, in a Fun City, that interior decorating is discouraged, etc.
Postby Azeem » Sun Nov 17, 2013 3:25 am
Apparently you can have different building text descriptions depending on your city type. Someone posted up modified building text files that reflected different city types, but I don't recall who it was.
Return to “Mods (Files)”
