My High Scores Aren't Saving
Everything Hinterland that doesn't fit elsewhere
Pat D.
Postby Pat D. » Mon Oct 06, 2008 10:00 am
Any one else not having their high scores save? I just have one at a time w/ no others saving...weird...
pat!
Duckling
Same problem
Postby Duckling » Mon Oct 06, 2008 12:10 pm
played two games so far and liking it, but it does however only show one highscore..
Livonya
Postby Livonya » Mon Oct 06, 2008 4:03 pm
The high score section is completely messed up.
Mine is a total mess. Every time I add a new game the last one gets messed up.
I think the high score section will have to be patched as it clearly does not work correctly.
- Livonya
Effidian
Postby Effidian » Mon Oct 06, 2008 4:08 pm
Same here. My high score list makes no sense whatsoever. Field are blanks, names are duplicated, etc.
I also think that you should be able to get all the information you get on the score summary at the end of the game. Maybe a "Details" button that gives you that.
But first a fix to make it work properly...
Gerblyn
Postby Gerblyn » Mon Oct 06, 2008 5:23 pm
I'm having the same problem, except I have two rows filled in. I thought the duplicated names was caused by me restarting over and over with the same character name though...
CustodianV131
Postby CustodianV131 » Tue Oct 07, 2008 10:10 pm
Try using different names for your characters for now. So far no problems here doing just that.
Effidian
Postby Effidian » Wed Oct 08, 2008 1:14 am
"CustodianV131" wrote:Try using different names for your characters for now. So far no problems here doing just that.
I've got a ton of characters with different names, but it is still all screwed up.
CustodianV131
Postby CustodianV131 » Wed Oct 08, 2008 8:07 pm
"Effidian" wrote:I've got a ton of characters with different names, but it is still all screwed up.
Oi nasty! :( Hopefully the upcomming patch will fix it. Might want to do a clean install then. Ain't nice losing high scores though. Tricky!
