DXdiag go here.
Feedback, suggestions and general discussion on Hinterland
JuliaSet
DXdiag go here.
Postby JuliaSet » Fri Aug 22, 2008 9:06 pm
Here are the stats for my best computer. I will add the second one later.
My Steam nick is JuliaSet.
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
BIOS: BIOS Date: 08/24/06 14:44:22 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz (2 CPUs)
Memory: 2944MB RAM
Page File: 229MB used, 6654MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DxDiag Version: 5.03.2600.5512 32bit Unicode
Card name: NVIDIA GeForce 8500 GT
Manufacturer: NVIDIA
Chip type: GeForce 8500 GT
DAC type: Integrated RAMDAC
Display Memory: 512.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7519 (English)
two monitors KDS and acer flat panel both with same resolution.
_KPaul
Postby _KPaul » Fri Aug 22, 2008 9:31 pm
Thanks, Julia. This is precisely something I was going to post next week, though it doesn't hurt that you started it early.
I would like all Insiders to post their DxDiags here. When posting your response, include the System Information and Display Devices sections from the TXT file in the post. Please attach the full TXT file, as well. If your system changes during the testing period, edit your original post to eliminate the old data and add a fresh post to the thread with the new information [to help keep me easily updated].
In case someone doesn't know, the DxDiag is a file that can be saved to your hard drive which details the hardware information of your system. It helps us nail down bugs that end up being specific to your hardware by allowing us to make comparisons between testers' systems. You can get your DxDiag file by going to Start >> Run, type in "dxdiag" [no quotes] and hit ENTER, and after the application has finished loading, you can hit the Save All Information button and choose a location on your hard drive.
Postby mouse » Fri Aug 22, 2008 10:34 pm
This is my second best computer since I had to trade my good computer to my son ;) His business came before gaming so after I did a complete rebuild of this computer it should be up to gaming :D
Miut
Miut's PC
Postby Miut » Sat Aug 23, 2008 2:00 am
Here's my baby. :)
Time of this report: 8/22/2008, 18:57:10
Machine name: SHOLA
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
System Manufacturer: Custom
System Model: Custom
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) X2 Dual Core Processor BE-2400, MMX, 3DNow (2 CPUs), ~2.3GHz
Memory: 2046MB RAM
Page File: 304MB used, 3635MB available
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8600 GT
Chip type: GeForce 8600 GT
Device Key: Enum\PCI\VEN_10DE&DEV_0402&SUBSYS_82431043&REV_A1
Current Mode: 1600 x 1200 (32 bit) (70Hz)
Monitor: Philips 109S (109S2)
Monitor Max Res: 1920,1440
DDI Version: 9 (or higher)
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Device Identifier: {D7B71E3E-4742-11CF-AC6E-48A200C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0402
SubSys ID: 0x82431043
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Pecunia
Postby Pecunia » Sat Aug 23, 2008 4:00 pm
Testing on my dad's PC since my own doesn't meet the minimum requirements (has Win2000 and 1.7GHz):
System Information
Time of this report: 8/23/2008, 17:54:40
Machine name: CHIMERA
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: Dutch)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 11/06/03 17:38:10 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 510MB RAM
Page File: 170MB used, 1077MB available
Display Devices
Card name: RADEON 9600 SERIES
Manufacturer: ATI Technologies Inc.
Chip type: ATI RADEON 9600 Series AGP (0x4150)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4150&SUBSYS_2066148C&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6618 (English)
Driver Date/Size: 6/7/2006 23:09:10, 260096 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/7/2006 23:08:56, 1580544 bytes
Device Identifier: {D7B71EE2-0210-11CF-E66E-6C00A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4150
SubSys ID: 0x2066148C
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
koppi
Postby koppi » Sat Aug 23, 2008 5:22 pm
This is the pc of my son
System Information
Time of this report: 8/23/2008, 19:14:30
Machine name: KWW005V64
Operating System: Windows Vista™ Ultimate (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080425-1930)
Language: German (Regional Setting: German)
System Manufacturer: System manufacturer
System Model: P5K
BIOS: BIOS Date: 03/05/08 17:17:05 Ver: 08.00.12
Processor: Intel(R) Core(TM)2 Duo CPU E8200 @ 2.66GHz (2 CPUs), ~2.7GHz
Memory: 4094MB RAM
Page File: 1957MB used, 6158MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DxDiag Version: 6.00.6001.18000 64bit Unicode
Display Devices
Card name: ATI Radeon HD 3800 Series
Chip type: ATI Radeon Graphics Processor (0x9501)
Device Key: Enum\PCI\VEN_1002&DEV_9501&SUBSYS_022A1043&REV_00
Display Memory: 2298 MB
Dedicated Memory: 507 MB
Shared Memory: 1791 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: SyncMaster 206BW,SyncMaster Magic CX206BW(Digital)
Driver Name: atidxx32,atidxx64.dll,atiumdag,atiumdva,atiumd64.dll,atiumd6a.cap,atitmm64.dll
Driver Version: 7.15.0010.0134 (English)
DDI Version: 10.1
Driver Date/Size: 8/1/2008 06:37:41, 1717248 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D641-11CF-A871-2022A1C2CA35}
Vendor ID: 0x1002
Device ID: 0x9501
SubSys ID: 0x022A1043
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_A ModeMPEG2_C
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D Status: Enabled
AGP Status: Enabled
Jaguar
Postby Jaguar » Sat Aug 23, 2008 5:57 pm
Until I get a huge problem resolved on my XP machine (I guess I didn't fix it) I'll be playing on the vista comp. Play time could be limited though, as I have to share this one :p
System Information
Time of this report: 6/5/2008, 17:55:18
Machine name: REN-PC
Operating System: Windows Vista™ Business (6.0, Build 6000) (6000.vista_gdr.071023-1545)
System Manufacturer: Dell Inc.
System Model: Vostro 400
Processor: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz (2 CPUs), ~2.3GHz
Memory: 2046MB RAM
Page File: 852MB used, 3473MB available
DxDiag Version: 6.00.6000.16386 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Chip type: GeForce 8800 GTS
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_C8153842&REV_A2
Display Memory: 1051 MB
Dedicated Memory: 284 MB
Shared Memory: 767 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dum.dll,nvwgf2um.dll
Driver Version: 7.15.0011.6375 (English)
DDI Version: 9Ex
Driver Date/Size: 10/4/2007 19:14:00, 4993024 bytes
WHQL Logo'd: n/a
Device Identifier: {D7B71E3E-42D3-11CF-1543-1EE802C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0xC8153842
Revision ID: 0x00A2
Revision ID: 0x00A2
Boaster
Postby Boaster » Sun Aug 24, 2008 5:13 pm
System Information
Time of this report: 8/24/2008, 12:06:55
Machine name: IMPERIAL
System Manufacturer: Unknow
System Model: Unknow
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6400+, MMX, 3DNow (2 CPUs), ~3.2GHz
Memory: 3518MB RAM
Page File: 466MB used, 4934MB available
Display Devices
Card name: NVIDIA GeForce 7050 PV / NVIDIA nForce 630a
Chip type: GeForce 7050 PV / NVIDIA nForce 630a
Device Key: Enum\PCI\VEN_10DE&DEV_053B&SUBSYS_1C2E147B&REV_A2
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Driver Version: 6.14.0011.0117 (English)
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_147BA601&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5672 (English)
WHQL Logo'd: n/a
Date and Size: 7/24/2008 20:02:44, 4749824 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
DxDiag attached.
Bugsy
Postby Bugsy » Sun Aug 24, 2008 6:34 pm
System Information
Time of this report: 8/24/2008, 14:30:19
Machine name: BUGSY
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
System Manufacturer: Compaq Presario 061
System Model: ED861AA-ABA SR1603WM NA540
BIOS: Phoenix - Award BIOS v6.00PG
Processor: AMD Sempron(tm) Processor 3200+, MMX, 3DNow, ~1.8GHz
Memory: 1342MB RAM
Page File: 426MB used, 2779MB available
Display Devices
Card name: ATI RADEON XPRESS 200 Series
Chip type: ATI RADEON XPRESS 200 Series (0x5954)
Device Key: Enum\PCI\VEN_1002&DEV_5954&SUBSYS_2A26103C&REV_00
Current Mode: 800 x 600 (32 bit) (70Hz)
Monitor: COMPAQ FS7600 Color Monitor
Monitor Max Res: 1280,1024
Driver Version: 6.14.0010.6553 (English)
Driver Date/Size: 6/8/2005 01:44:56, 232448 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 6/8/2005 01:44:36, 1235968 bytes
Device Identifier: {D7B71EE2-1A14-11CF-156A-2C0AA1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5954
SubSys ID: 0x2A26103C
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
EmperorJay
Postby EmperorJay » Mon Aug 25, 2008 11:34 am
Here you go!
Jaguar
Postby Jaguar » Mon Sep 01, 2008 9:42 pm
Brand new Vista system:
System Information
Time of this report: 9/1/2008, 15:39:55
Machine name:
Operating System: Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_gdr.071023-1545)
System Manufacturer: Gateway
System Model: GM5478
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 2030MB RAM
Page File: 1759MB used, 2517MB available
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Device Key: Enum\PCI\VEN_10DE&DEV_0421&SUBSYS_047D10DE&REV_A1
Display Memory: 1004 MB
Dedicated Memory: 245 MB
Shared Memory: 758 MB
Driver Version: 7.15.0011.7519 (English)
DDI Version: 9Ex
Driver Date/Size: 5/16/2008 14:01:00, 5689344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4761-11CF-316E-762401C
aramann
Postby aramann » Sat Sep 06, 2008 1:56 pm
Here is my dxdiag.
Danimusrex1
my laptop
Postby Danimusrex1 » Sat Sep 06, 2008 1:58 pm
here it is
PhilL
lap top info
Postby PhilL » Sat Sep 06, 2008 2:20 pm
steam name Betadata
System Information
Time of this report: 8/26/2008, 21:49:28
Machine name: 30DP2694
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
System Model: Latitude D630
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A09
Processor: Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 459MB used, 3479MB available
Display Devices
Card name: NVIDIA Quadro NVS 135M
Chip type: Quadro NVS 135M
Device Key: Enum\PCI\VEN_10DE&DEV_042B&SUBSYS_01F91028&REV_A1
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Version: 6.14.0011.0119 (English)
Driver Date/Size: 4/28/2007 19:05:00, 5464320 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 4/28/2007 19:05:00, 6727136 bytes
Device Identifier: {D7B71E3E-476B-11CF-EF73-F22100C2CB35}
Vendor ID: 0x10DE
Device ID: 0x042B
SubSys ID: 0x01F91028
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Rorschach
Dxdiag
Postby Rorschach » Sat Sep 06, 2008 2:22 pm
System Information
Time of this report: 9/6/2008, 07:15:05
Machine name: XERXES
Operating System: Windows Vista™ Home Premium (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080425-1930)
System Manufacturer: OEM
System Model: OEM
Processor: Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz (2 CPUs), ~3.0GHz
Memory: 2046MB RAM
Page File: 3182MB used, 1287MB available
DxDiag Version: 6.00.6001.18000 32bit Unicode
Display Devices
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042010DE&REV_A2
Monitor: NEC MultiSync 90GX2
Driver Version: 7.15.0011.6906 (English)
DDI Version: 10
Driver Date/Size: 11/6/2007 21:00:00, 5263360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-42D3-11CF-9469-2B2402C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x042010DE
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D Status: Enabled
AGP Status: Enabled
Lugburz
Postby Lugburz » Sat Sep 06, 2008 2:27 pm
Here ya go!
System Information
Time of this report: 9/6/2008, 08:20:27
Machine name:
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.050928-1517)
System Manufacturer: powerspec4.2e
System Model: ps9501
Processor: AMD Athlon(tm) 64 Processor 4000+, MMX, 3DNow, ~2.4GHz
Memory: 2048MB RAM
Page File: 349MB used, 3590MB available
Display Devices
Card name: NVIDIA GeForce 7800 GT
Chip type: GeForce 7800 GT
Device Key: Enum\PCI\VEN_10DE&DEV_0092&SUBSYS_C5183842&REV_A1
WHQL Logo'd: Yes
VDD: n/a
Device Identifier: {D7B71E3E-43D2-11CF-AD46-13E500C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0092
SubSys ID: 0xC5183842
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Zorglub
Postby Zorglub » Sat Sep 06, 2008 2:41 pm
System Information
Time of this report: 7/2/2008, 20:06:16
Machine name: BLEURG-BPD7NIL1
Language: French (Regional Setting: French)
System Model: P5K
Processor: Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 361MB used, 3578MB available
Display Devices
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_C8013842&REV_A2
Monitor: Écran Plug-and-Play
Driver Version: 6.14.0011.6921 (English)
Driver Date/Size: 12/5/2007 01:41:00, 5773568 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 12/5/2007 01:41:00, 7435392 bytes
Device Identifier: {D7B71E3E-4551-11CF-FB40-0AE803C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0xC8013842
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
adbos974
Postby adbos974 » Sat Sep 06, 2008 3:09 pm
hi all
this my pc dxdiag
tomnobles - dxdiag.txt
Postby tomnobles » Sat Sep 06, 2008 3:25 pm
Here is sys info and display info for my system. The original that was sent when I applied for beta testing is no longer valid. That computer is going into retirement. :)
My Steam Nick is tomnobles.
System Information
Time of this report: 9/6/2008, 08:06:24
Machine name: TOM
System Manufacturer: XFX
System Model: MG-63MI-7059
Processor: Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 828MB used, 3110MB available
Display Devices
Device Key: Enum\PCI\VEN_10DE&DEV_0421&SUBSYS_C7933842&REV_A1
Display Memory: 1024.0 MB
Current Mode: 1024 x 768 (32 bit) (70Hz)
Driver Version: 6.14.0011.6402 (English)
Driver Date/Size: 3/17/2008 03:51:04, 5784064 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 3/17/2008 03:51:04, 6866912 bytes
Device Identifier: {D7B71E3E-4761-11CF-F042-98E700C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0421
SubSys ID: 0xC7933842
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Kiya
Postby Kiya » Sat Sep 06, 2008 3:31 pm
My dxdiag
Return to “Hinterland Beta (General)”
