DXdiag go here.
Feedback, suggestions and general discussion on Hinterland
Raikoh
Postby Raikoh » Sat Sep 06, 2008 4:28 pm
Here is mine:
Cyrilion
Postby Cyrilion » Sat Sep 06, 2008 4:39 pm
Better add mine too :)
System Information
Time of this report: 9/6/2008, 18:33:44
Machine name: ALLAN-E8400
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: Danish)
System Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
System Model: MS-7519
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs)
Memory: 3072MB RAM
Page File: 607MB used, 4348MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 9800 GTX
Manufacturer: NVIDIA
Chip type: GeForce 9800 GTX
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0612&SUBSYS_82861043&REV_A2
Display Memory: 512.0 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7516 (English)
DDI Version: 9 (or higher)
Driver Date/Size: 5/2/2008 22:46:00, 6108160 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/2/2008 22:46:00, 6554496 bytes
Device Identifier: {D7B71E3E-4552-11CF-AF6E-8DA203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0612
SubSys ID: 0x82861043
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
aeval99
Postby aeval99 » Sat Sep 06, 2008 7:20 pm
Here we go.
soldyne
Postby soldyne » Sat Sep 06, 2008 7:21 pm
This is my info!
thegrad
Dx files
Postby thegrad » Sat Sep 06, 2008 9:12 pm
Here is mine
ContractMan
Postby ContractMan » Sat Sep 06, 2008 9:35 pm
dxdiag attached
Stringbags
Postby Stringbags » Sat Sep 06, 2008 10:12 pm
This is the info for my main desktop computer.
System Information
Time of this report: 9/6/2008, 23:05:46
Machine name: HOME
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 01/12/07 13:15:38 Ver: 08.00.12
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, MMX, 3DNow (2 CPUs), ~3.0GHz
Memory: 3072MB RAM
Page File: 661MB used, 4295MB available
Windows Dir: F:\WINDOWS
DX Setup Parameters: None
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8600 GTS
Chip type: GeForce 8600 GTS
Device Key: Enum\PCI\VEN_10DE&DEV_0400&SUBSYS_043810DE&REV_A1
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Version: 6.14.0011.6371 (English)
Driver Date/Size: 9/17/2007 09:07:00, 5783040 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 9/17/2007 09:07:00, 6853088 bytes
Device Identifier: {D7B71E3E-4740-11CF-8D6B-332400C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0400
SubSys ID: 0x043810DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0400
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Postby sakasiru » Sat Sep 06, 2008 11:41 pm
This is the PC I´m currently playing on. if I use another, I will post the DX then.
Edit: Added the AthlonMP.
Hyjynx
Postby Hyjynx » Sun Sep 07, 2008 1:05 am
Here is the poor Hamster wheel that I will be testing this game on :(
(DxDiag attached)
And my steam name is: Jynxed1
*edit - helps if I actually attach it...
ramuhotep
Postby ramuhotep » Sun Sep 07, 2008 2:37 am
My dxdiag is not quite the same as the one I submitted with my application. Had to do some fiddling.
Kars-T
Postby Kars-T » Sun Sep 07, 2008 10:41 am
My DXDIag
hotshot1084
Postby hotshot1084 » Sun Sep 07, 2008 2:52 pm
System Information
Time of this report: 9/7/2008, 07:46:17
Machine name: NICHOLAS1084
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: P35-DS3L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 655MB used, 3284MB available
Display Devices
Card name: NVIDIA GeForce 8800 GT
Chip type: GeForce 8800 GT
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_C8023842&REV_A2
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: ViewSonic VX910
Monitor Max Res: 1280,1024
Driver Version: 6.14.0011.7519 (English)
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: Yes
VDD: n/a
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Device Identifier: {D7B71E3E-4551-11CF-AD46-09E803C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0xC8023842
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Arthur
Postby Arthur » Sun Sep 07, 2008 5:58 pm
Used to have a 4600+ but it fried itself >.>
Nothing against AMD but they seem to fail in that aspect sometimes
(Should be getting a new system around January with a Nehalem CPU :3)
Postby Azeem » Sun Sep 07, 2008 6:54 pm
This is the dxdiag for my "main" laptop; I'll be using my other laptop later until I get an adapter plug (it's a Korean laptop).
Kernel
Postby Kernel » Mon Sep 08, 2008 3:35 am
My laptop:
System Information
Time of this report: 8/7/2008, 21:51:36
Machine name: CRIMSON
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
System Manufacturer: eMachine
System Model: Shadow-K8
BIOS: PhoenixBIOS 4.0 Release 6.0
Processor: Mobile AMD Athlon(tm) 64 Processor 3000+, MMX, 3DNow, ~1.8GHz
Memory: 1278MB RAM
Page File: 503MB used, 882MB available
Display Devices
Card name: ATI MOBILITY RADEON 9600/9700 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI MOBILITY RADEON 9600/9700 Series AGP (0x4E50)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E50&SUBSYS_2032161F&REV_00
Display Memory: 64.0 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Generic Television
Monitor Max Res: 640,480
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6631 (English)
Driver Date/Size: 8/2/2006 17:08:06, 258048 bytes
WHQL Logo'd: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/2/2006 17:07:51, 1681920 bytes
Device Identifier: {D7B71EE2-0D10-11CF-486C-3800A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E50
SubSys ID: 0x2032161F
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
iuvart
Postby iuvart » Mon Sep 08, 2008 11:54 am
System Information
Time of this report: 8/27/2008, 16:32:09
Machine name: SERVER
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.070227-2300)
Language: German (Regional Setting: German)
System Manufacturer: ASUSTeK Computer Inc.
System Model: F3JA
Processor: Genuine Intel(R) CPU T2250 @ 1.73GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 791MB used, 4108MB available
Display Devices
Card name: ATI Mobility Radeon X1600
Chip type: ATI display adapter (0x71C5)
Device Key: Enum\PCI\VEN_1002&DEV_71C5&SUBSYS_10B21043&REV_00
Monitor: (Standardmonitor)
Monitor Max Res:
Driver Date/Size: 8/2/2006 06:08:08, 258048 bytes
WHQL Logo'd: Yes
VDD: Nicht zutreffend
Mini VDD Date: 8/2/2006 06:07:52, 1681920 bytes
Device Identifier: {D7B71EE2-3285-11CF-146A-B830A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x71C5
SubSys ID: 0x10B21043
Revision ID: 0x0000
Revision ID: 0x0000
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Postby Azeem » Mon Sep 08, 2008 5:08 pm
DxDiag for my Korean laptop.
I will be using the new laptop for the remainder of the test; my old laptop went haywire after installing Steam for reasons unknown.
DMDickson
DxDiag
Postby DMDickson » Thu Sep 11, 2008 12:44 pm
My computer:
System Information
Time of this report: 9/11/2008, 08:37:11
Machine name: MNHMDD06
Operating System: Windows Vista™ Ultimate (6.0, Build 6000) (6000.vista_ldr.071023-1545)
System Manufacturer: Hewlett-Packard
System Model: Blackbird-002
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Extreme CPU Q6850 @ 3.00GHz (4 CPUs), ~3.3GHz
Memory: 2046MB RAM
Page File: 1512MB used, 2814MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DxDiag Version: 6.00.6000.16386 32bit Unicode
Graphics Adapters:
Display Devices
Card name: NVIDIA GeForce 8800 Ultra
Chip type: GeForce 8800 Ultra
Device Key: Enum\PCI\VEN_10DE&DEV_0194&SUBSYS_C8863842&REV_A2
Display Memory: 1503 MB
Dedicated Memory: 736 MB
Shared Memory: 767 MB
Current Mode: 2560 x 1600 (32 bit) (60Hz)
Monitor: HP LP3065 Wide LCD Monitor
Driver Name: nvd3dum.dll,nvwgf2um.dll
Driver Version: 7.15.0011.7519 (English)
DDI Version: 9Ex
Driver Date/Size: 5/16/2008 14:01:00, 5689344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-42D4-11CF-AD46-8DE802C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0194
SubSys ID: 0xC8863842
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
I don't know if you can tell from the report or not, but there are two 8800's configured as one using SLI...
Inky
DxDiag Info
Postby Inky » Fri Sep 12, 2008 9:07 pm
System Information
Time of this report: 8/26/2008, 18:18:03
Machine name: VOODOO
Operating System: Windows Vista™ Ultimate (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080425-1930)
Memory: 2814MB RAM
Page File: 1306MB used, 4533MB available
DxDiag Version: 6.00.6001.18000 32bit Unicode
Display Devices
Display Memory: 1887 MB
Shared Memory: 1151 MB
Monitor: SyncMaster 226BW(Analog)
DDI Version: 10
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x0194
Revision ID: 0x00A2
Revision ID: 0x00A2
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D Status: Enabled
AGP Status: Enabled
Return to “Hinterland Beta (General)”
