Alexandria won't install
Oregon Taz
Postby Oregon Taz » Tue Dec 02, 2008 10:48 pm
When I try to install Alexandria I get an error message "Children of the Nile is not installed. Please install CotN...". I installed CotN in the default place and the enhanced version is running OK. What do I need to do to get Alexandria installed?
Thanks, Oregon Taz
Postby tomnobles » Tue Dec 02, 2008 10:55 pm
Sorry, this may not be much help but;
The company you got it from should be able to help you. I got mine from GamersGate & had no problem.
Oregon Taz
Postby Oregon Taz » Wed Dec 03, 2008 2:16 am
The rep at d2d suggested I try installing it in safe mode, but that didn't help.
I need to find out why the install package is not recognizing that CotN IS installed. Even if I got it from GamerGate I think I would have the same problem. But thanks for your reply.
*back to NO* :p
Jarardo
Postby Jarardo » Thu Dec 04, 2008 7:35 pm
I'm having the same problem. I'll post back here if I figure it out.
Postby Keith » Thu Dec 04, 2008 8:36 pm
You should first post your dxdiag.txt file as an attachment to your original request for help. That way we can get an idea of what is sort of system you have and what drivers are involved, etc.
Right now we don't have enough information to even start giving you any suggestions. We don't even know what version of Windows you are running.
Always post a dxdiag.txt file when asking for help. If you make any changes later on and still have a problem attach a new copy of the dxdiag.txt file at that time.
To attach a file, use the manage attachments button below the reply window.
If you have any sort of virtual drive software like Daemon Tools, Anti-Blaax, Alcohol %120, CloneCD, etc. you may have to remove or disable that software as it may be conflicting with the security software of the game and the installer.
Disable any AV software before installing. These can interfere with installs and the proper registering of files in the system registry.
Although it didn't work in your case, using the Windows Safe Mode often does work with problem installs.
If you are installing the game on some other drive or other install path than the default C: drive install path you may want to try installing it to the default install path to see if that works. Some installers have problems with "other paths" for some reason.
If you have any unessential USB devices plugged into the computer at the time of the install, unplug those before running the installer.
In the case of a game that comes on a disc, (not your case), you can also copy the entire disc to a new folder on your hard drive and run the installer from there. Your's is already a hard drive install because it is a digital download.
Make sure that the Windows local user account you are using has administrator priveledges on your system. If it does not you re-login on the Windows System Administrator account, the create a new user account and give it administrator priveledges. Then use that new account to login and play the game.
Jarardo
Postby Jarardo » Thu Dec 04, 2008 9:43 pm
I have two installs of windows, both XP this one I use for games, it's a very clean install. I tried re-installing on both partitions(the other is C :) , to the default directory. It hasn't worked, :(
Thanks for any help!
System Information
Time of this report: 12/4/2008, 14:38:36
Machine name: SUPER
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: VIA Technologies, Inc.
System Model: VT8367-8233
BIOS: Award Modular BIOS v6.00PG
Processor: AMD K7 processor, MMX, 3DNow, ~2.0GHz
Memory: 1536MB RAM
Page File: 308MB used, 3125MB available
Windows Dir: F:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Radeon X1650 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter AGP (0x71C7)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_71C7&SUBSYS_0850174B&REV_9E
Display Memory: 512.0 MB
Current Mode: 1024 x 768 (32 bit) (72Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6706 (English)
DDI Version: 9 (or higher)
Driver Date/Size: 6/26/2007 18:58:34, 269312 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/26/2007 18:58:16, 2303488 bytes
Device Identifier: {D7B71EE2-3287-11CF-C96E-5A283FC2CB35}
Vendor ID: 0x1002
Device ID: 0x71C7
SubSys ID: 0x0850174B
Revision ID: 0x009E
Revision ID: 0x009E
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Vinyl AC'97 Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_30041695&REV_40
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: vinyl97.sys
Driver Version: 6.14.0001.4170 (English)
WHQL Logo'd: Yes
Date and Size: 8/10/2006 06:32:14, 204672 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: F:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1033, 0x0035
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 11/4/2008 08:31:49, 59520 bytes
| Driver: usbd.sys, 11/4/2008 08:31:49, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 11/4/2008 08:31:47, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 4/13/2008 16:15:30, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 11/4/2008 08:31:44, 52480 bytes
| Driver: kbdclass.sys, 11/4/2008 08:31:45, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 04:43:22, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC03D
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 11/4/2008 08:31:48, 23040 bytes
| Driver: mouhid.sys, 11/4/2008 08:31:44, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 3.1 GB
Total Space: 25.0 GB
File System: NTFS
Model: Maxtor 6Y120P0
Drive: E:
Free Space: 5.9 GB
Total Space: 80.2 GB
File System: NTFS
Drive: F:
Free Space: 4.6 GB
Total Space: 12.0 GB
File System: NTFS
Drive: J:
Free Space: 30.2 GB
Total Space: 100.0 GB
File System: NTFS
Model: ST3500630A
Drive: K:
Free Space: 4.3 GB
Total Space: 176.0 GB
File System: NTFS
Model: ST3500630A
Drive: N:
Free Space: 2.0 GB
Total Space: 200.9 GB
File System: NTFS
Model: ST3500630A
Drive: G:
Model: LITE-ON DVD SOHD-16P9SV
Driver: f:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:43, 62976 bytes
Drive: H:
Model: SONY DVD RW DRU-810A
Drive: D:
Model: EVE OXUBCP2BKXE SCSI CdRom Device
System Devices
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B099&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: F:\WINDOWS\system32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/1/2003 19:42:00, 27904 bytes
Name: VIA Standard PCI to ISA Bridge
Device ID: PCI\VEN_1106&DEV_3147&SUBSYS_00000000&REV_00\3&61AAA01&0&88
Driver: F:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 16:06:42, 37248 bytes
Name: VIA CPU to PCI Bridge
Device ID: PCI\VEN_1106&DEV_3099&SUBSYS_00000000&REV_00\3&61AAA01&0&00
Driver: n/a
Name: Vinyl AC'97 Codec Combo Driver (WDM)
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_30041695&REV_40\3&61AAA01&0&8D
Driver: F:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 23:15:16, 60160 bytes
Driver: F:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 23:49:42, 146048 bytes
Driver: F:\WINDOWS\system32\drivers\stream.sys, 5.03.0001.0904 (English), 7/9/2004 04:27:28, 48512 bytes
Driver: F:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 04:42:46, 23552 bytes
Driver: F:\WINDOWS\system32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytes
Driver: F:\WINDOWS\system32\drivers\vinyl97.sys, 6.14.0001.4170 (English), 8/10/2006 06:32:14, 204672 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61AAA01&0&8B
Driver: F:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:49, 20608 bytes
Driver: F:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:49, 143872 bytes
Driver: F:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 21:42:10, 74240 bytes
Driver: F:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:49, 59520 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61AAA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61AAA01&0&89
Driver: F:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 4/13/2008 16:10:32, 5376 bytes
Driver: F:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:47, 24960 bytes
Driver: F:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:43, 96512 bytes
Name: NETGEAR FA311v2 PCI Adapter
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_F31D1385&REV_10\3&61AAA01&0&60
Driver: F:\WINDOWS\system32\DRIVERS\FA311XP.SYS, 5.635.0923.2005 (English), 1/24/2006 17:38:40, 78720 bytes
Name: NEC PCI to USB Enhanced Host Controller (B1)
Device ID: PCI\VEN_1033&DEV_00E0&SUBSYS_00E01735&REV_02\3&61AAA01&0&5A
Driver: F:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:49, 30208 bytes
Driver: F:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 11/4/2008 08:31:44, 7168 bytes
Name: NEC PCI to USB Open Host Controller
Device ID: PCI\VEN_1033&DEV_0035&SUBSYS_00351735&REV_41\3&61AAA01&0&59
Driver: F:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 11/4/2008 08:31:49, 17152 bytes
Device ID: PCI\VEN_1033&DEV_0035&SUBSYS_00351735&REV_41\3&61AAA01&0&58
Name: Radeon X1650 Series Secondary
Device ID: PCI\VEN_1002&DEV_71E7&SUBSYS_0851174B&REV_9E\4&618BA55&0&0108
Driver: F:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6706 (English), 6/26/2007 18:58:16, 2303488 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0012 (English), 6/26/2007 18:15:32, 49152 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 6/26/2007 19:27:54, 44240 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ativckxx.vp, 8/23/2006 14:26:56, 2096 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 4/18/2007 05:19:24, 929 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 4/18/2007 05:19:24, 1311202 bytes
Driver: F:\WINDOWS\system32\DRIVERS\ativdkxx.vp, 4/18/2007 05:19:50, 2096 bytes
Driver: F:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6706 (English), 6/26/2007 18:58:34, 269312 bytes
Driver: F:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0345 (English), 6/26/2007 18:10:32, 376832 bytes
Driver: F:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 6/26/2007 18:51:00, 26112 bytes
Driver: F:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0510 (English), 6/26/2007 18:41:08, 2940992 bytes
Driver: F:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0161 (English), 6/26/2007 18:31:02, 1519744 bytes
Driver: F:\WINDOWS\system32\atiicdxx.dat, 6/5/2007 10:40:44, 149278 bytes
Driver: F:\WINDOWS\system32\ativvaxx.dat, 6/26/2007 18:30:44, 3107788 bytes
Driver: F:\WINDOWS\system32\ativva5x.dat, 6/26/2007 18:30:44, 3107788 bytes
Driver: F:\WINDOWS\system32\ativva6x.dat, 6/26/2007 18:30:44, 972072 bytes
Driver: F:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 6/26/2007 18:48:32, 53248 bytes
Driver: F:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 6/26/2007 18:16:12, 17408 bytes
Driver: F:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 08:01:04, 24064 bytes
Driver: F:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4173 (English), 6/26/2007 18:49:20, 483328 bytes
Driver: F:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4163 (English), 6/26/2007 18:50:42, 118784 bytes
Driver: F:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2521 (English), 6/26/2007 18:51:20, 143360 bytes
Driver: F:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0020 (English), 6/26/2007 18:51:08, 122880 bytes
Driver: F:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2512 (English), 6/26/2007 18:50:54, 43520 bytes
Driver: F:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0061 (English), 6/26/2007 18:17:34, 266240 bytes
Driver: F:\WINDOWS\system32\atifglpf.xml, 4/11/2007 18:33:46, 7069 bytes
Driver: F:\WINDOWS\system32\ATIDEMGX.dll, 2.00.2733.37788 (English), 6/26/2007 18:59:38, 344064 bytes
Driver: F:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6645 (English), 6/26/2007 18:19:32, 5435392 bytes
Driver: F:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.0001 (English), 6/26/2007 18:14:30, 176128 bytes
Driver: F:\WINDOWS\system32\atioglx2.dll, 6.14.0010.6645 (English), 6/26/2007 18:44:54, 8232960 bytes
Driver: F:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4005 (English), 6/26/2007 18:56:42, 307200 bytes
Driver: F:\WINDOWS\atiogl.xml, 5/3/2007 10:52:52, 11557 bytes
Device ID: PCI\VEN_1002&DEV_71C7&SUBSYS_0850174B&REV_9E\4&618BA55&0&0008
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 11/4/2008 08:31:44 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 11/4/2008 08:31:44 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 11/4/2008 08:31:44 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:45 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 11/4/2008 08:31:44 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:48 35328 bytes
gameenum.sys: 5.01.2600.5512 English Final Retail 4/13/2008 16:15:30 10624 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 11/4/2008 09:21:43 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 11/13/2008 13:00:08 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 11/13/2008 12:29:22 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 11/13/2008 12:29:23 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 11/13/2008 12:29:23 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 11/13/2008 12:29:24 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 11/13/2008 12:29:24 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 11/13/2008 12:29:24 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 11/13/2008 12:29:24 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 11/13/2008 12:29:25 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 11/13/2008 12:29:25 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 11/13/2008 13:00:08 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:08 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:09 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:09 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:09 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:08 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:08 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 11/13/2008 13:00:08 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 11/4/2008 08:31:45 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 11/4/2008 08:31:45 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 11/4/2008 08:31:51 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:43 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 11/4/2008 08:31:44 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:45 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:46 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:46 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:44 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 11/4/2008 08:31:47 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 733696 bytes
quartz.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:47 1288192 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 11/4/2008 08:31:49 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/4/2008 08:31:44 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/4/2008 08:31:45 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/4/2008 08:31:45 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/4/2008 08:31:45 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/4/2008 08:31:45 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/4/2008 08:31:45 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/4/2008 08:31:45 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/4/2008 08:31:45 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:46 203776 bytes
ks.sys: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:48 141056 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:48 4352 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:46 118272 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 11/4/2008 08:31:46 1428992 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:49 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:48 16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 11/4/2008 08:31:51 50688 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
Jarardo
Postby Jarardo » Thu Dec 04, 2008 9:44 pm
Here's the rest:
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ATI Media Center Video Encoder,0x00600000,1,1,atimcenc.dll,9.14.0000.60829
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0005.1925
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1925
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0005.1925
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Mpeg Source,0x00200000,0,0,MpegSplitter.ax,1.00.0000.0005
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
ATI EZShare Server,0x00200000,1,0,atidvcr.dll,9.14.0000.4873
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
ATI EZShare Client,0x00200000,0,1,atidvcr.dll,9.14.0000.4873
CyberLink Video/SP Decoder (PDVD8),0x00600000,2,3,CLVSD.ax,8.01.0000.1513
ATI Time Shift Splitter,0x00600000,1,2,atidvcr.dll,9.14.0000.4873
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,9.14.0000.4873
ATI MPEG File Writer,0x00200000,1,0,atidvcr.dll,9.14.0000.4873
ATI MPEG Video Decoder,0x005fffff,1,2,atidvcr.dll,9.14.0000.4873
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0004
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
ATI VCR Video Converter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
FLV Splitter,0x00800001,1,1,FLVSplitter.ax,1.00.0000.0004
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5512
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.08.0122.0018
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.08.0122.0018
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Media Center Audio Encoder,0x00600000,1,1,atimcenc.dll,9.14.0000.60829
MP4 Splitter,0x00600001,1,1,MP4Splitter.ax,1.00.0000.0004
ATI CC Multiplexer,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ATI MPEG Audio Encoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
ATI VCR Stream Sink,0x00200000,0,0,atidvcr.dll,9.14.0000.4873
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
ATI Media Center Multiplexer,0x00400000,2,1,atimcenc.dll,9.14.0000.60829
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
ATI MPEG Video Encoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Haali Video Renderer,0x00200000,1,0,dxr.dll,
ATI MPEG Multiplexer,0x00200000,2,1,atidvcr.dll,9.14.0000.4873
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
FLV4 Video Decoder,0x00400000,1,1,FLVSplitter.ax,1.00.0000.0004
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
ATI Video Scaler Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.08.0122.0018
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001.0004
Avi Splitter,0x00600001,1,1,avisplitter.ax,1.00.0000.0009
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.0004
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.08.0122.0018
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
ATI CC Splitter Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0005.1925
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.5512
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
FLV Source,0x00600001,0,0,FLVSplitter.ax,1.00.0000.0004
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
Avi Source,0x00600001,0,0,avisplitter.ax,1.00.0000.0009
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0004
Arcsoft Snapshot Filter 1.0,0x00200000,1,1,ArcSnap.ax,1.00.0000.0020
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1925
Mpeg Splitter,0x00400001,1,1,MpegSplitter.ax,1.00.0000.0005
ATI Video Rotation Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0004
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.08.0122.0018
ATI VCR Stream Source,0x00600000,0,0,atidvcr.dll,9.14.0000.4873
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
ATI FM-On-Demand Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0005.1925
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Audio Capture Sources:
Vinyl AC'97 Audio (WAVE),0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming Capture Devices:
Vinyl AC'97 Audio (WAVE),0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.5512
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming System Devices:
Vinyl AC'97 Audio (WAVE),0x00200000,12,2,,5.03.0000.0900
Gray Wolf
Postby Gray Wolf » Fri Dec 05, 2008 7:39 pm
"Oregon Taz" wrote:When I try to install Alexandria I get an error message "Children of the Nile is not installed. Please install CotN...". I installed CotN in the default place and the enhanced version is running OK. What do I need to do to get Alexandria installed?
Thanks, Oregon Taz
dxdiag file attached
Postby Keith » Fri Dec 05, 2008 8:21 pm
"Jarardo" wrote:I have two installs of windows, both XP this one I use for games, it's a very clean install. I tried re-installing on both partitions(the other is C :) , to the default directory. It hasn't worked, :(
Are those hard drive partitions compressed or uncompressed?
The game requires installation on a uncompressed drive or partition.
Both XP installs are on the same machine?
Alexandria is a addon to CotN not the whole game. Do you have Children of the Nile 1.3 enhanced (Steam) version installed? You need that first before you can install Alexandria.
The rest of your dxdiag.txt file looks okay.
"Gray Wolf" wrote:dxdiag file attached
I'm not sure why you have this but it looks like you need to update your DirectX install with a more recent 9.0c version, because of this:
DirectX Files Tab: The file d3d9d.dll is a debug version, which will run slower than the retail version.You could probably use newer video and audio drivers, but they won't cause this sort of problem with the installer.
If you both have tried all the things I mentioned in my previous post and this one and it stll can't find the game I don't know what else to tell you.
The technical support for the Steam versions are supposed to come from Steam because they alter the game from it's original form to make it available as a digital download and they provide the installer for it.
Jarardo
Postby Jarardo » Sat Dec 06, 2008 4:58 pm
"Keith" wrote:Are those hard drive partitions compressed or uncompressed?
The drives are uncompressed. Both XP installs are on the same machine.
The original game is installed off the CotN CD. I downloaded the 1.3 patch from Tilted Mill and upgraded with that.
You mentioned Steam, sorry for any confusion but I got my Alexandria expansion from Direct2Drive.
Postby Keith » Sat Dec 06, 2008 5:49 pm
I"m just guessing that the installer may be getting confused by the dual XP install.
The digital download versions of the game need to create a Tilted Mill folder in the My Documents folder of the Windows account user being used. Having two installs of XP may be giving it a problem locating the proper location.
It may also be part of the reason why it may not "see" the install of CotN on your system.
I assume that you are installing the Alexandria update from the same account that you installed CotN and patch 1.3 with.
Oregon Taz
Postby Oregon Taz » Sat Dec 06, 2008 6:15 pm
I updated my dx file, it didn't help. I got Alexandria from 2d2. I hope they will have a solution next week. Thanks for your time, Shirley
Jarardo
Postby Jarardo » Sun Dec 07, 2008 1:11 am
"Keith" wrote:I"m just guessing that the installer may be getting confused by the dual XP install.
I don't see why having two installs would affect anything. They are on totally separate partitions. One is C: the other is F:. Shouldn't it be looking at registry files or something?
Oregon Taz
Postby Oregon Taz » Sun Dec 07, 2008 6:45 pm
d2d support said that my CotN came from a box and I was trying to add Alexandria digitally was the problem. He very kindly added $19.95 to my account so I could purchase the digital version of CotN. I did this and Alexandria installed OK.
FYI - d2d was VERY helpful in solving this problem. :D Several days worth of emails even on Saturday.
Postby tomnobles » Fri Dec 12, 2008 4:24 pm
That's nice to know info. I have the box version. I also have Alexandria. I purchased it from GamersGate and it installed with no problems.
I always assumed that it made no difference where you got it it was the same. Apparently I was mistaken.
archonsod
Postby archonsod » Mon Dec 15, 2008 8:23 pm
Depends on the version. D2D have their own proprietary DRM wrapper on all their games, so in general expansions / updates etc only work for the D2D version. They used to be a horribly long gap between a patch being released and it actually becoming available for the D2D version, but they seem to be improving in that respect.
Gamer's Gate, Impulse and in certain cases Steam tend to provide the exact same files you see on the retail release, so it's usually a question of whether the retail game has any DRM which the patch/update effects (if it does you may see a demand for the disk when you try to run the game). One nice side effect of the GG version of Alexandria is I no longer need to find my CoTN disk to play it ;)
Return to “Alexandria”
