The game is obscenely slow.
Azzents
Postby Azzents » Sat Nov 13, 2010 5:23 am
Ok. I was a little generous when I say "game". I just purchased this on Steam and as soon as I ran it it took a while for the logos to appear. I dismissed this and made my character and got to the loading screen.
That's as far as I've gotten. On my first try I literally 38 minutes loading the game world before I gave up and tried to start over but to no avail.
After looking through some forum posts I've found no such post with this problem and decided to save you some time and post my dxdiag straight off.
Thanks in advance.
zemog
Postby zemog » Sun Dec 26, 2010 5:29 am
I have a similar problem, takes forever to get game to start after picking job, pic and name then it takes forever to create world and whatever else it does. alt-tabbing during this process is the only way to even get progress on the create world screen and the following creations. it hangs up on enemy placement and never goes beyond this.
zemog
Postby zemog » Sun Dec 26, 2010 5:32 am
Edit: your own support forum wont accept .log file uploads?
Edit 2: for some reason I can't get the upload page to recognize the .log files changed into .txt files as valid files for uploading so here is wall of text
//-------------------------- 12/25/2010 -- 22:20:19 -----
--------- Loading DIRS ---------
Missing file: c:/program files/steam/steamapps/common/hinterland/tools/main.cs!
Error: Unable to find specified directory: tools
--------- Parsing Arguments ---------
--------- Initializing Directory: scriptsAndAssets ---------
--------- Initializing Language ---------
Language English [scriptsAndAssets/Localization/English/English.lso] activated.
--------- End Initializing Language ---------
Language ID: 0
Reading Display Device information...
Primary Display Device Found:
Vendor Id: VEN_0000
Device Id: DEV_0000
Binding server port to default IP
UDP initialized on port 0
DirectX 9 version - 9.0.0 c
DirectX 8 version - 9.0.0 c
Attempting to create GFX device: NVIDIA GeForce 8800 GTS (Omega 2.169.21) (D3D9)
Device created, setting adapter and enumerating modes
GFXD3D9Device - using 'd3dx9_33.dll' for dynamic linking.
D3DDevice ref count is 1
Pix version detected: 3.000000
Vert version detected: 3.000000
Maximum number of simultaneous samplers: 8
Initializing GFXCardProfiler (D3D9)
o Vendor : 'NVIDIA (Omega 2.169.21)'
o Card : 'NVIDIA GeForce 8800 GTS (Omega 2.169.21)'
o Version: '69.21'
- Scanning card capabilities...
- Loading card profiles...
- Loading card profile profile/D3D9.cs
- No card profile profile/D3D9.NVIDIAOmega216921.cs exists
- No card profile profile/D3D9.NVIDIAOmega216921.NVIDIAGeForce8800GTSOmega216921.cs exists
- No card profile profile/D3D9.NVIDIAOmega216921.NVIDIAGeForce8800GTSOmega216921.6921.cs exists
Texture Manager
- Approx. Available VRAM: 567279616
- Threshold VRAM: 67108864
- Quality mode: high
% - Initialized Common
Object 'CrossbowProjectile' is not a member of the 'ProjectileData' data block class
Object 'CrossbowFireSound' is not a member of the 'SFXProfile' data block class
Object 'CrossbowReloadSound' is not a member of the 'SFXProfile' data block class
Object 'CrossbowFireEmptySound' is not a member of the 'SFXProfile' data block class
Loading light datablocks from: common/lighting/lights/
Loading light datablocks from: common/lighting/filters/
*** effect loading
ParticleEmitterData(StaffGlowEmitter) thetaMax > 180.0
ParticleEmitterData(WandGlowEmitter) thetaMax > 180.0
ParticleEmitterData(CastHealGlowEmitter) thetaMax > 180.0
ParticleEmitterData(CastBlessGlowEmitter) thetaMax > 180.0
ParticleEmitterData(CastCurseGlowEmitter) thetaMax > 180.0
Object 'dbProc_PlaguePoison' is not a member of the 'ItemProcData' data block class
**** Loading itemProcs
Warning! You have a duplicate datablock name of setRandomEffects. This can cause problems. You should rename one of them.
Set Up Sounds
sfxStartup...
Provider: DirectSound
Device: Primary Sound Driver
Hardware: No
Buffers: 16
Object 'FootLightSoftSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightHardSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightMetalSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightSnowSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightShallowSplashSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightWadingSound' is not a member of the 'SFXProfile' data block class
Object 'FootLightUnderwaterSound' is not a member of the 'SFXProfile' data block class
Object 'Bolt_WandEmitter' is not a member of the 'ParticleEmitterData' data block class
Missing file: c:/program files/steam/steamapps/common/hinterland/scriptsAndAssets/materials.cs!
--------- Initializing Hinterland: Server Scripts ---------
--------- Initializing Hinterland: Client Scripts ---------
Attempting to set resolution to "1024 768 false 32 60 0"
Accepted Mode:
--Resolution : 1024 768
--Full Screen : No
--Bits Per Pixel : 32
--Refresh Rate : 60
--FSAA Level 0
GFXPCD3D9Device::reset - depthstencil 1822c0 has 2 ref's
--- Resetting D3D Device ---
Missing file: c:/program files/steam/steamapps/common/hinterland/scriptsAndAssets/retail/distributerStartupGui.gui!
IsDirectory: traversing all resources to look for directory
--- loadStartup ---
Engine initialized...
Steam: Requesting stats...
Steam: user stats received
isPlayGuiActive: Unknown command.
--- initClient2 ---
Res:1024 768
fontSet:3
*** Load Main Menu
Res:1024 768
fontSet:3
Attempting to set resolution to "1280 1024 0 32 60 0"
Warning: The requested windowed resolution is equal to or larger than the current desktop resolution. Attempting to find a better resolution
Warning: Switching to "1024 768 32"
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
GFXPCD3D9Device::reset - depthstencil 18fd40 has 2 ref's
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
Attempting to set resolution to "1024 768 0 32 60 0"
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
Connect request from:
Connection established 6285
CADD: 6286 local
*** Sending mission load to client:
*** GameConnection::startScenarioCreation ***
Mapping string: ServerMessage to index: 0
Mapping string: MsgConnectionError to index: 1
Attempting to set resolution to "1280 1024 1 32 60 0"
Accepted Mode:
--Resolution : 1280 1024
--Full Screen : Yes
--Refresh Rate : 60
--FSAA Level 0
Win32Window::setMode - invoking curtain
Res:1032 802
Accepted Mode:
--Full Screen : Yes
--Refresh Rate : 60
--FSAA Level 0
CDROP: 6286 local
Connect request from: IP:0.0.0.0:0
Connection established 6348
CADD: 6349 local
Accepted Mode:
--Full Screen : Yes
--Refresh Rate : 60
--FSAA Level 0
CDROP: 6349 local
Connection established 6359
CADD: 6360 local
Win32Window::WindowProc - resetting device due to window size change.
Res:1280 1024
Res:1280 1024
fontSet:1
Mapping string: MsgLoadInfo to index: 2
Mapping string: MsgLoadDescripition to index: 3
Mapping string: MsgLoadInfoDone to index: 4
Mapping string: MsgClientJoin to index: 5
Mapping string: Welcome to a Torque application %1. to index: 6
Mapping string:  Poser to index: 7
Mapping string: MissionStartPhase1 to index: 8
*** New Mission:
*** Phase 1: Download Datablocks & Targets
Mapping string: ScenarioGenPhase1 to index: 9
*** clientCmdScenarioGenPhase1 ***
Mapping string: MissionStartPhase1Ack to index: 0
Mapping string: ScenarioGenPhase1Ack to index: 1
*** serverCmdScenarioGenPhase1Ack ***
Mapping string: ScenarioGenPhase2 to index: 10
*** clientCmdScenarioGenPhase2 ***
Mapping string: ScenarioGenPhase2Ack to index: 2
*** serverCmdScenarioGenPhase2Ack ***
GFXD3D9Device::beginScene - Device needs to be reset, waiting on device...
GFXD3D9Device::beginScene - Device needs to be reset, resetting device...
waiting for dxdevice
Res:1280 1024
AtlasClipMapImageCache_Blender::registerSourceImage - couldn't locate texture 'c:/program files/steam/steamapps/common/hinterland/scriptsAndAssets/data/Default' for blending.
Allocating a 1024 px clipmap for a 32768px source texture.
- 5 base clipstack entries, + 1 cap.
- Using approximately 31.920000MB of texture memory.
Ghost Always objects received.
Mapping string: ScenarioGenPhase3 to index: 11
*** clientCmdScenarioGenPhase3 ***
Mapping string: ScenarioGenPhase3Ack to index: 3
zemog
Postby zemog » Sun Dec 26, 2010 5:35 am
second and third console.log files pertaining to above post
//-------------------------- 12/25/2010 -- 22:42:06 -----
Language ID: 0
Vendor Id: VEN_0000
Device Id: DEV_0000
o Version: '69.21'
Texture Manager
- Approx. Available VRAM: 566231040
*** effect loading
Set Up Sounds
sfxStartup...
Hardware: No
Buffers: 16
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
GFXPCD3D9Device::reset - depthstencil 1822e0 has 2 ref's
--- loadStartup ---
--- initClient2 ---
Res:1024 768
fontSet:3
*** Load Main Menu
Res:1024 768
fontSet:3
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
Connection established 6262
CADD: 6263 local
CDROP: 6263 local
Connection established 6272
CADD: 6273 local
*** New Mission:
*** serverCmdScenarioGenPhase3Ack ***
ClipMap::texCB - took 16 ms to fill clipmap after zombification.
Res:1024 768
GFXPCD3D9Device::reset - depthstencil b5b7de0 has 2 ref's
ClipMap::texCB - took 15 ms to fill clipmap after zombification.
Res:1024 768
Terraformer::getCameraPosition: could not get camera.
Terraformer::setCameraPosition: could not get camera.
Trying to create ambient with bogus datablock: AnimalFurs2
Texturing Terrain
Done Texturing Terrain
CDROP: 6273 local
loading sounds...
sounds loaded.
Exporting server prefs...
Loaded Item Sets XML file OK
Loaded Item Slots XML file OK
*** LOADING MISSION: C:/Documents and Settings/AJ/My Documents/Tilted Mill/Hinterland/saves/Searle.mis
*** Stage 1 load
*** Stage 2 load
*** Mission loaded
Connection established 8606
CADD: 8607 local
*** Sending mission load to client: C:/Documents and Settings/AJ/My Documents/Tilted Mill/Hinterland/saves/Searle.mis
Mapping string:  Searle to index: 7
*** New Mission: C:/Documents and Settings/AJ/My Documents/Tilted Mill/Hinterland/saves/Searle.mis
Mapping string: MissionStartPhase2 to index: 9
*** Phase 2: Download Ghost Objects
Mapping string: MissionStartPhase2Ack to index: 1
Mapping string: MissionStartPhase3 to index: 10
Client Replication Startup has Happened!
fxFoliageReplicator - replicated client foliage for 0 objects
*** Phase 3: Mission Lighting
Lighting mission....
Synapse Gaming Lighting Pack
Starting scene lighting...
Starting TGE based scene lighting...
Lighting with light #1 (TGE vector light)...
Lighting terrain, object 1 of 1...
Object lighting complete (3.875 seconds)
TGE based scene lighting complete (46.406 seconds)
Starting Synapse Gaming Lighting Pack scene lighting...
Lighting object 1 of 1... TerrainBlock: (null)
Object lighting complete (5.328 seconds)
Synapse Gaming Lighting Pack scene lighting complete (144.297 seconds)
Lighting Pack lighting system stats:
Interior Lexel Count: 0
Interior Lexel Illumination Count: 0
Interior Lexel Illumination Time (ms): 0.000000
Interior Lexel Illumination Time Total (ms): 0
Interior Lexel Diffuse Count: 0
Interior Object Count: 1
Interior Object Included Count: 0
Interior Object Illumination Count: 0
Interior Surface Included Count: 0
Interior Surface Illumination Count: 0
Interior Surface Illuminated Count: 0
Interior Surface Smoothed Count: 0
Interior Surface Smoothed Lexel Count: 0
Interior Surface Setup Count: 0
Interior Surface Setup Time Total (ms): 0
Interior Surface Merge Count: 0
Interior Surface Merge Time Total (ms): 0
Static Mesh BVPT Potential Occluder Count: 0
Static Mesh Cast Ray Mesh Count: 0
Static Mesh Surface Occluder Count: 0
Terrain Lexel Count: 0
Terrain Lexel Time (ms): 0.000000
Terrain Lexel Time Total (ms): 0
Successfully saved mission lighting file: 'C:/Documents and Settings/AJ/My Documents/Tilted Mill/Hinterland/saves/Searle_55d0903esg.ml'
Scene lighting complete (174.391 seconds)
Mission lighting done
Mapping string: MissionStartPhase3Ack to index: 2
Mapping string: MissionStart to index: 11
Mapping string: SyncClock to index: 12
********** CREATING CHARACTER *****************
Creating new game for character: Searle
** Creating Lord **
Created building with id 9719
Placed: dbBuildingOutpost -- TQ: 0
<input> (0): Unable to find function AddTown
No Building for: dbEncDef_Orc level: 3
No Building for: dbEncDef_Dark_Elf level: 0
No Building for: dbEncDef_Skeleton level: 0
No Building for: dbEncDef_Skeleton level: 2
No Building for: dbEncDef_Zombie level: 2
No Building for: dbEncDef_Barbarian level: 6
No Building for: dbEncDef_Minotaur level: 7
No Building for: dbEncDef_Troll level: 7
Character creation finished. Creation time: 916.297 seconds
Mapping string: clearObstructingObjects to index: 13
ClipMap::texCB - took 31 ms to fill clipmap after zombification.
Res:1024 768
*** Initial Control Object
scriptsAndAssets/client/scripts/serverConnection.cs (39): Unable to find function Editor::checkActiveLoadDone
Mapping string: Searle to index: 14
Mapping string: hf_f_meda_leath to index: 15
Mapping string: meda to index: 16
Mapping string: hf_boots_leather to index: 17
Mapping string: boots to index: 18
Mapping string: hf_glove_leath to index: 19
Mapping string: glove to index: 20
Mapping string: hf_f_skin_drk to index: 21
Mapping string: skin to index: 22
Mapping string: hf_hair_black to index: 23
Mapping string: hair to index: 24
50...waiting for 29 ghost(s)
49...waiting for 29 ghost(s)
48...waiting for 29 ghost(s)
47...waiting for 29 ghost(s)
46...waiting for 29 ghost(s)
Res:1024 768
45...waiting for 29 ghost(s)
44...waiting for 29 ghost(s)
43...waiting for 29 ghost(s)
42...waiting for 29 ghost(s)
41...waiting for 29 ghost(s)
40...waiting for 29 ghost(s)
39...waiting for 29 ghost(s)
Steam: shutting down Steam API...
CDROP: 8607 local
*** ENDING MISSION
Exporting client prefs
Stopping sound streaming thread
Cur. D3DDevice ref count=1
zemog
Postby zemog » Sun Dec 26, 2010 5:38 am
third and for now final console.log file since renaming, resaving, copying the .log text into a fresh txt file doesn't work for me. sorry, been trying to get game to work for about 4 hours now and I just don't have the patience to figure out this upload problem since I dont see any stickies on forums about proper procedures
//-------------------------- 12/25/2010 -- 23:07:06 -----
Language ID: 0
Vendor Id: VEN_0000
Device Id: DEV_0000
o Version: '69.21'
Texture Manager
*** effect loading
Set Up Sounds
sfxStartup...
Hardware: No
Buffers: 16
Accepted Mode:
--Full Screen : No
--Refresh Rate : 60
--FSAA Level 0
GFXPCD3D9Device::reset - depthstencil 1821c0 has 2 ref's
--- loadStartup ---
--- initClient2 ---
Res:1024 768
fontSet:3
*** Load Main Menu
Res:1024 768
fontSet:3
loading sounds...
Res:1024 769
Res:1031 778
Res:1047 787
Res:1058 791
Res:1077 792
Res:1093 798
Res:1095 799
Res:1095 801
Res:1097 807
Res:1108 821
Res:1115 830
Res:1119 836
Res:1124 843
Res:1127 849
Res:1129 853
Res:1131 856
Res:1133 860
Res:1134 862
Res:1136 868
Res:1138 869
sounds loaded.
*** Stage 1 load
*** Stage 2 load
*** Mission loaded
Connection established 7393
CADD: 7394 local
Successfully loaded mission lighting file: 'C:/Documents and Settings/AJ/My Documents/Tilted Mill/Hinterland/saves/Searle_55d0903esg.ml'
********** LOADING SAVE *****************
ClipMap::texCB - took 32 ms to fill clipmap after zombification.
Res:1138 869
CDROP: 7394 local
*** ENDING MISSION
Postby Keith » Sun Dec 26, 2010 10:31 am
"Azzents" wrote:Ok. I was a little generous when I say "game". I just purchased this on Steam and as soon as I ran it it took a while for the logos to appear. I dismissed this and made my character and got to the loading screen.
Thanks in advance.
First, let me say that I do not have Hinterland, but it should be similar to CotN and Caesar IV in overall design.
The only thing I see in your dxdiag.txt file that could use updating is the sound driver. It's from 2006.
There is a chance that these old drivers could be causing the slow loading of the game. You can try disabling these sound drivers from the Hardware Device Manager menu to see if it is the cause of the problem without making any permanent changes to your system.
You can get there by right-clicking on the My Computer icon on the desktop or on the START menu.
Choose Properties.
Choose the Hardware tab and click the Device Manger button.
Find the Sound, video and game controlers section. Click on the '+' to expand the list.
Find the listing for the Realtek HD Audio output and right-click on that item.
Select Disable.
Close the menu and reboot the computer.
Try the game. If it loads up right away its your sound system giving you the problem.
You can re-enable the sound by doing the above steps and selecting Enable from the list then rebooting the computer.
If the game loads, update your sound drivers to a newer version. Follow the manufacturer's instructions on how to do this properly. Don't just install the new version over the old.
Postby Keith » Sun Dec 26, 2010 10:39 am
zemog, it seems like the game is having a lot of issues with your video setup.
The log seems to indicate that you are running the game in a windowed mode, but the window you want to run it in is larger than the desktop resolution you have set.
You may want to try either increasing your desktop resolution to one equal to or greater than the size of the window you want to run the game in or use a smaller window to run the game in.
You didn't attach a copy of your dxdiag.txt file so I can't tell if there are any other issues.
