Log your combat results here
Jonath
Postby Jonath » Sat Dec 06, 2008 10:07 pm
We should try to figure out just how combat results are calculated. Once we have enough results logged, we should be able to figure it out with matrix algebra or the like. So, please log your combat results here, and try to keep other chatter to a minimum.
Alternately, if someone has an active SurveyMonkey account, perhaps they can set up a survey.
First entry:
You sent 27SP 39AR 26CH
Bandits had 45SP 35AR 30CH
You killed 24SP 35AR 8CH
Bandits killed 22SP 27AR 13CH
Bandits captured 1SP 2AR
Jonath
Back into the breech
Postby Jonath » Sat Dec 06, 2008 10:21 pm
You sent 14SP 13AR 23CH
Bandits had 22SP 2AR 22CH
You killed 12SP 2AR 8CH
Bandits killed 5SP 13AR 7CH
Bandits captured 1SP 0AR 1CH
Beamup
Postby Beamup » Sat Dec 06, 2008 10:34 pm
You sent 49 23 48
Bandits had 2 0 13
Combat Details
You killed 2 0 11 of the enemy army
Bandits killed 0 3 4 of your army
You captured 0 0 2 from Bandits!
Result
You took over the monument plot!
You attacked Bandits on 12:26pm 12/06/2008
You sent 49 49 49
Bandits had 45 35 30
Combat Details
You killed 33 35 17 of the enemy army
Bandits killed 19 35 10 of your army
You captured 10 0 0 from Bandits!
Result
Bandits kept the monument!
dymo
Postby dymo » Sat Dec 06, 2008 10:36 pm
You sent 38s 19a 32c
Bandits had 5s 0a 15c
Combat Details
You killed 4s 0a 15c of the enemy army
Bandits killed 1s 7a 2c of your army
You captured 1s 0a 0c from Bandits!
Result
AnimalC
Postby AnimalC » Sat Dec 06, 2008 10:37 pm
You sent 48 37 37
Combat Details
You killed 27 35 8 of the enemy army
Bandits killed 28 37 15 of your army
Result
Tahngarth
Location: Tomoo - entombed at 8N Sabah, theoris - tomoo - 6S,36S,38S
Postby Tahngarth » Sat Dec 06, 2008 10:49 pm
You attacked Bandits on 4:20pm 12/06/2008
You sent 0 5 21
Bandits had 4 0 11
Combat Details
You killed 4 0 7 of the enemy army
Bandits killed 0 4 3 of your army
Result
You attacked Bandits on 1:01pm 12/06/2008
You sent 0 0 5
Bandits had 4 0 11
Combat Details
You killed 0 0 1 of the enemy army
Bandits killed 0 0 4 of your army
Bandits captured 0 0 1 from you!
Result
You attacked Bandits on 3:55am 12/06/2008
You sent 0 0 1
Bandits had 19 0 20
Combat Details
You killed 0 0 0 of the enemy army
Bandits killed 0 0 1 of your army
Bandits captured 0 0 0 from you!
Result
You attacked Bandits on 3:52am 12/06/2008
You sent 0 1 22
Bandits had 24 0 25
Combat Details
You killed 4 0 4 of the enemy army
Bandits killed 0 1 19 of your army
Result
You attacked Bandits on 3:25am 12/06/2008
You sent 0 12 60
Bandits had 43 35 30
Combat Details
You killed 15 35 9 of the enemy army
Bandits killed 0 12 27 of your army
Bandits captured 0 0 7 from you!
Result
You attacked Bandits on 5:05pm 12/05/2008
You sent 0 0 1
Bandits had 45 25 20
Combat Details
You killed 1 1 1 of the enemy army
Result
lynnk
Postby lynnk » Sat Dec 06, 2008 11:21 pm
These combat results include me accidentally attacking myself :o :D
You attacked Lynnkx on 8:06am 12/06/2008
You sent 13 13 13
Lynnkx had 17 4 16
Combat Details
You killed 9 4 6 of the enemy army
Lynnkx killed 6 10 5 of your army
Lynnkx captured 0 3 0 from you!
Result
Lynnkx kept the monument!
You attacked Bandits on 11:31pm 12/05/2008
You sent 15 3 17
Bandits had 8 0 11
Combat Details
You killed 6 0 10 of the enemy army
Bandits killed 2 2 3 of your army
You captured 2 0 0 from Bandits!
Result
You attacked Bandits on 11:03pm 12/05/2008
You sent 17 4 22
Bandits had 16 0 19
Combat Details
You killed 8 0 8 of the enemy army
Bandits killed 5 4 7 of your army
Result
You attacked Bandits on 10:31pm 12/05/2008
You sent 40 40 40
Combat Details
You killed 26 31 11 of the enemy army
Bandits killed 27 40 16 of your army
You captured 3 4 0 from Bandits!
Result
herbstwerk
Postby herbstwerk » Sat Dec 06, 2008 11:29 pm
all so far were more minimal approaches as it seems... send a few and hope, repeat until taken... boooring. ;)
since i don't like wasting men and resources (exept bread to feed the survivors) here's a more "shock and awe"-like result. :)
You attacked Bandits on 7:24am 12/06/2008
You sent 65 66 65
Combat Details
You killed 35 35 27 of the enemy army
Bandits killed 13 25 7 of your army
You captured 10 0 2 from Bandits!
Result
Postby vic_4 » Sat Dec 06, 2008 11:55 pm
These are my results:
Soldiers currently in-mission
No soldiers currently on a mission.
You attacked Bandits on 4:10am 12/06/2008
You sent 17 1 28
Bandits had 9 0 17
Combat Details
You killed 7 0 12 of the enemy army
Bandits killed 2 1 3 of your army
You captured 1 0 4 from Bandits!
Result
You attacked Bandits on 3:42am 12/06/2008
You sent 44 44 44
Combat Details
You killed 36 35 10 of the enemy army
Bandits killed 25 43 15 of your army
You captured 0 0 3 from Bandits!
Result
CppThis
Postby CppThis » Sun Dec 07, 2008 1:43 am
I present for your pleasure the Battle of Raone. Some background: I wasnt quite set up for full on military when it got implemented (was expecting it to come next week tbh), so rather than one big zerg rush I had two forces at two cities, one to move in first and soften up the bandits, then the main force to mop up.
Sent the suicide force in first, to make things easier for the main force as they were only 150 rather than the 200 I had wanted. They were outnumbered about 3 to 1, so the outcome was pretty predictable.
You attacked Bandits on 7:53pm 12/06/2008
You sent 21 0 19
Combat Details
You killed 3 14 2 of the enemy army
Bandits killed 21 0 15 of your army
Bandits captured 0 0 4 from you!
Result
They killed about 15% of the enemy force, which is what I wanted. Next came the main force led by the elite Bear Cavalry to finish the job. Or so I had hoped, anyway...
You attacked Bandits on 7:59pm 12/06/2008
You sent 90 21 39
Bandits had 42 21 32
Combat Details
You killed 36 17 18 of the enemy army
Bandits killed 24 21 8 of your army
You captured 0 4 3 from Bandits!
Result
What?!? How can this be? But the bears never lose! Bandits were badly mauled, to be sure, but apparently my guys pulled out once they took just under 33% losses (101 of 150 survived). Payback time!!!
You attacked Bandits on 8:28pm 12/06/2008
You sent 62 5 34
Bandits had 6 0 11
Combat Details
You killed 5 0 9 of the enemy army
Bandits killed 4 1 0 of your army
You captured 1 0 2 from Bandits!
Result
Interestingly, these numbers dont quite match up. Either bandit strength is not actually persistent unit-by-unit, rather a single 'total units' number, capture is not working right, or some combination of the two. There were only about half as many units as there should have been based on casualties from the previous battle, though it wouldnt have made much difference. :cool:
omicron1
Postby omicron1 » Sun Dec 07, 2008 4:38 am
You sent 1 Chariot. Bandits had 5, 5, 4. Result: Bandits kept the plot.
You sent 1 Chariot. Bandits had 5, 5, 4. Result: Bandits kept the plot. (repeat 130x)
This was right after they spawned, when the infinite army trick was in place. I guess they operate by the rule of ninja or something.
Fashah
Postby Fashah » Sun Dec 07, 2008 8:36 am
I attacked once....and lost in both of my cities...and attacked immediately...and won them both...here is my log:
You attacked Bandits on 12:41am 12/07/2008
You sent 24 9 33
Bandits had 2 0 12
Combat Details
You killed 2 0 12 of the enemy army
Bandits killed 2 3 1 of your army
You captured 0 0 0 from Bandits!
Result
You sent 23 8 28
Bandits had 3 0 11
Combat Details
You killed 3 0 11 of the enemy army
Result
You attacked Bandits on 12:14am 12/07/2008
You sent 41 43 41
Combat Details
You killed 40 35 15 of the enemy army
Bandits killed 18 34 10 of your army
You captured 0 0 1 from Bandits!
Result
You attacked Bandits on 12:05am 12/07/2008
You sent 42 42 42
Combat Details
You killed 38 35 16 of the enemy army
Bandits killed 20 34 12 of your army
Result
Michlo
Location: Originally Merseyside, England now Los Angeles, USA
Postby Michlo » Sun Dec 07, 2008 10:09 am
You attacked Bandits on 4:28am 12/07/2008
You sent 44 Image 60 Image 44 Image
Combat Details
You killed 35 28 14 of the enemy army
Bandits killed 17 36 11 of your army
You captured 8 7 4 from Bandits!
Result
You attacked Bandits on 5:01am 12/07/2008
You sent 35 Image 31 Image 33 Image
Bandits had 0 0 11
Combat Details
You killed 0 0 9 of the enemy army
Bandits killed 0 3 0 of your army
Result
onemagicdaddy
Location: Overseer Xenith : Xenthia (3S), Xenthan (7S), Xenthos (1S)
Postby onemagicdaddy » Sun Dec 07, 2008 10:22 am
You attacked Bandits on 9:58am 12/06/2008
You sent 72 73 7
Combat Details
You killed 31 26 16 of the enemy army
Bandits killed 31 53 2 of your army
You captured 10 1 0 from Bandits!
Result
You attacked Bandits on 10:59am 12/06/2008
You sent 53 16 7
Bandits had 4 8 14
Combat Details
You killed 4 6 14 of the enemy army
Bandits killed 4 7 0 of your army
You captured 0 2 0 from Bandits!
Result
Ramiz
Location: Theoris » Osirisxeru (87N) » Inferno /// Bosnia and Herzegovina » Sarajevo
Postby Ramiz » Sun Dec 07, 2008 10:36 am
You attacked Bandits on 6:02pm 12/06/2008
You sent 33 0 23
Bandits had 11 0 16
Combat Details
You killed 11 0 16 of the enemy army
Bandits killed 4 0 3 of your army
Result
You attacked Bandits on 5:35pm 12/06/2008
You sent 56 31 31
Combat Details
You killed 29 35 11 of the enemy army
Bandits killed 26 31 9 of your army
You captured 3 0 2 from Bandits!
Result
Rama-Seph
Postby Rama-Seph » Sun Dec 07, 2008 1:04 pm
You attacked Bandits on 7:13pm 12/06/2008
You sent 35 45 45
Combat Details
You killed 31 35 10 of the enemy army
Bandits killed 22 45 15 of your army
You captured 5 0 3 from Bandits!
Result
You attacked Bandits on 8:14pm 12/06/2008
You sent 18 18 18
Bandits had 9 0 17
Combat Details
You killed 9 0 14 of the enemy army
Bandits killed 2 13 2 of your army
Result
Ghimen
Postby Ghimen » Sun Dec 07, 2008 2:12 pm
Here you can find my combat logs:
You attacked Bandits on 4:02am 12/07/2008
You sent 15 0 19
Bandits had 5 0 6
Combat Details
You killed 4 0 6 of the enemy army
Bandits killed 1 0 3 of your army
You captured 1 0 0 from Bandits!
Result
You attacked Bandits on 3:34am 12/07/2008
You sent 16 0 20
Bandits had 13 0 19
Combat Details
You killed 6 0 9 of the enemy army
Bandits killed 3 0 4 of your army
Result
You attacked Bandits on 3:06am 12/07/2008
You sent 43 36 30
Bandits had 37 35 30
Combat Details
You killed 24 35 11 of the enemy army
Bandits killed 28 36 10 of your army
Result
Davus Antonius
Postby Davus Antonius » Sun Dec 07, 2008 10:30 pm
You attacked Bandits on 4:53pm 12/07/2008
You sent 34 49 34
Combat Details You killed 31 30 14 of the enemy army
Bandits killed 20 40 10 of your army
You captured 4 5 0 from Bandits!
Result Bandits kept the monument!
You attacked Bandits on 5:24pm 12/07/2008
You sent 16 14 23
Bandits had 7 0 14
Combat Details You killed 6 0 14 of the enemy army
Bandits killed 1 10 3 of your army
Result You took over the monument plot!
Leperous
Postby Leperous » Sun Dec 07, 2008 11:42 pm
Weellll, so far, in general, it looks like if you kill over 60% of the enemy you win but they keep the plot, and that you need an 80% victory to capture it. I think there's a random element to whether or not you capture the plot or not after a victory but it's much more likely to happen the more of the enemy you kill (obviously).
I'd like to make the prediction that sending 45,35,30 against an enemy army of 45, 35, 30 (the 'standard' size) that you'll lose and 50,50,50 will probably outright win the plot. (55,55,55 should for sure.)
Sooper Tooter
Postby Sooper Tooter » Mon Dec 08, 2008 12:33 am
Basically, I sent a big army, and killed a lot of the bandits, but they still kept the plot, so I sent in what was left, and killed the rest and took the plot.
Also, I should note that I sent 1 archer to the monument while my big army was still fighting. I got the monument plot with the big army, but by the time the archer got there, I already won, so he attacked my army! He was killed unceremoniously, apparently for being slow and a traitor.
You attacked Bandits on 1:22pm 12/06/2008
You sent 11 16 54
Bandits had 2 0 13
Combat Details
Bandits killed 0 5 1 of your army
Result
You attacked Bandits on 12:50pm 12/06/2008
You sent 26 53 72
Combat Details
You killed 43 28 17 of the enemy army
Bandits killed 14 44 18 of your army
You captured 0 7 0 from Bandits!
Result
