"Help" window
Torgen
"Help" window
Postby Torgen » Sat Nov 22, 2008 5:32 pm
All it says is "This is a test" when you click the "?" Help button.
Matt Zimmitti
Postby Matt Zimmitti » Mon Nov 24, 2008 4:42 pm
Um, we are not getting this at all internally despite several attempts to reproduce it. Is it consistently happening for you no matter what?
Postby vic_4 » Mon Nov 24, 2008 5:30 pm
I get the same problem.
Matt Zimmitti
Postby Matt Zimmitti » Mon Nov 24, 2008 5:32 pm
Does it happen on the Confederacy Level as well?
Postby vic_4 » Mon Nov 24, 2008 6:08 pm
Yes, it does, I had not tried it. When I start a new game, however, it works well.
Jim Solomon
Steps to Reproduce?
Postby Jim Solomon » Mon Nov 24, 2008 10:18 pm
Is there a method you all are using to get this to happen?
I am guessing it doesn't happen when you first go into to combat or into the confederacy level. Does it occur when you close the panel then reopen? Does it occur using the 'h' key?
Thanks!
Postby vic_4 » Mon Nov 24, 2008 10:36 pm
Pretty strange. I restarted the game and help worked, I did a couple of mission and it worked, then I reloaded the save where it did not work, and now it works. I don't know, I did nothing different. I always open the help through the button.
Ouijdani
Postby Ouijdani » Tue Nov 25, 2008 12:59 am
I get the "This is a test" help window sometimes when I hit "H" and other times I get the actual help content. I use "H" to pause, so I see it a lot.
Ouij
Matt Zimmitti
Postby Matt Zimmitti » Tue Nov 25, 2008 3:35 pm
Ok thanks guys. Jim sorted this out and the fix will be in the next build we put up.
(thanks Jim)
~Z
