Newb Help?
All discussion regarding the world of Sabah
lisfyre
Newb Help?
Postby lisfyre » Fri Aug 14, 2009 4:39 pm
Hi everyone!!
OK Sorry to be a pain but, I've got my workers working on everything. I followed the primer. I now have a Bakery and a Brickworks. But I'm out of bread to feed people. And I can't buy it at the market... well I guess I can't since bread is the currency right? So... how do I get over this hump? My bakers are baking but obviously not enough to feed everyone...
Any tips or tricks or hints would be so appreciated. Thanks in advance.
Anonymous Top Ranker
Postby Anonymous Top Ranker » Fri Aug 14, 2009 5:04 pm
Don't forget to employ enough workers on the wheat field to harvest the wheat your bakers need. Without wheat, your bakers are not baking bread.
You know how much wheat 1 baker requires per hour? 12 lb. So you need to produce 12 lb of wheat for every baker.
joshofet
Postby joshofet » Fri Aug 14, 2009 6:24 pm
You don't have to employ all your workers, be sure to have enough workers in the wheat field and the bakery to keep the others working. You can deassign workers from other industries and boost bread production.
BTW: this seems like a general question, you could have asked in the general forum. :)
lisfyre
Postby lisfyre » Fri Aug 14, 2009 6:28 pm
Yes I have maxed workers in the wheat field (level 1) and I made sure I had at least 100 wheat before I built the bakery. But I ran out of bread after I built the bakery. It's slow going. I guess I have to sit tight for a bit.
Ivy
Postby Ivy » Fri Aug 14, 2009 7:31 pm
If your wheatfield is level 1 you probably need to upgrade it pretty soon. It's hard to advise though without knowing where all your workers are. Starting out is a constant juggling act. Don't be afraid to keep moving your workers around! :)
Postby PantherX » Sat Aug 15, 2009 5:56 am
Yep, it's all about the waiting game, upgrade wheat then bakery. You may need to actually stop making bricks while your wheat field or bakery upgrade. But the game is all about labor allocation and upgrade cycles :)
Good luck!
joshofet
Postby joshofet » Sat Aug 15, 2009 9:58 am
You don't have to build stocks, employ workers so that stocks don't dwindle. that applies for wheat as well as bread.
lisfyre
Postby lisfyre » Mon Aug 17, 2009 7:44 pm
Thanks for all the answers and tips everyone!!
OK new newb question :) lol :)
I finally got an Exchange. HEre's the thing, I can't send messages to anyone to trade for cedar so I can build ships. I can't even write anything on the scribe wall or any wall.
Need help with these issues if someone can give me some tips please and thanks. Also I don't have much... currency wise and my sandal shop is just starting to produce sandals but if someone would like to trade 1:1 .. I can only offer sandals since that's the only lux item I have. :)
abana
Postby abana » Mon Aug 17, 2009 7:49 pm
Did you activate your acount, you should have gotten an email, click on the link in that email. I think that will do it.
lisfyre
Postby lisfyre » Mon Aug 17, 2009 7:51 pm
Yes I did and it tells me that my account is already activated. :confused:
I just tried activating it and I get the same message - my account has already been activated.
abana
Postby abana » Mon Aug 17, 2009 8:15 pm
Ok, that isn't it. What browser are you using? There have been some problems with IE. How are you attempting to send a scroll? The scroll icon is circled in green, the wall icon is circled in red.
joshofet
Postby joshofet » Mon Aug 17, 2009 9:21 pm
Actually it is verification that you need. If you click on your name to bring up your profile page, at the "Change Email" topic, is your current email address listed, and does it say VERIFIED?
lisfyre
Postby lisfyre » Tue Aug 18, 2009 12:59 am
I am using Firefox and no it says the email is unverified. Weird.
Postby Tinkerbell » Tue Aug 18, 2009 3:54 am
Howdy, lisfyre!
You should have an email sent to your address with a verification link that you have to activate to be allowed to send scrolls & use the three Scribe Walls. It should have been sent when you started your account. Is the email address on your profile correct? Also check your other email folders, like spam etc.
lisfyre
Postby lisfyre » Tue Aug 18, 2009 3:23 pm
Hello Tinkerbell :) Yes the first email they sent was all correct. I finally asked for another activation email to be sent today and now I can reply and send messages. Weird that the first one didn't work. Thanks so much :)
Postby Tinkerbell » Tue Aug 18, 2009 3:38 pm
Excellent! You are now all set, lisfyre.
Have fun! :)
Malkata
Postby Malkata » Tue Aug 18, 2009 5:45 pm
I had the same problem as Lisfyre using Firefox 3. In the end I deleted the account and re-registered using IE 7 (urg!) it verified via the email in exactly the same way but this time everything was active.
So, I have to use IE7 .to play online
abana
Postby abana » Tue Aug 18, 2009 7:15 pm
no. you can use the others. just log in with your chosen browser.
Ivy
Postby Ivy » Tue Aug 18, 2009 8:57 pm
That's true.... now you are in, you could try Firefox again, if that is what you normally use. People play with all sorts of browsers, including IE, FF, Opera, Chrome and Safari.
Return to “World - Sabah”
